Bulbs behind the 4x4 and warning lights #1041402 02/03/12 08:52 PM
Schoeny Offline OP
Anyone know the size of the bulbs? I've got a few burned out in my 1995 LS. I've searched through the service manual, but don't see any reference to them at all, searching here returned the same result. Maybe I'm looking for the wrong words, but I can't find anything.
If not, I plan on working on getting them replaced this weekend, but won't have access to another car. If I pull the bezel and bulbs, is it going to hurt anything to drive a couple blocks down the road to the parts store? Not worried about the safety/legality as it's a 35MPH street, and I'll be going less than that with/without the panel installed. Or do I need to at least get all the connectors plugged back in temporarily?
1995 Montero LS
Re: Bulbs behind the 4x4 and warning lights [Re: Schoeny] #1041403 02/03/12 09:03 PM
LandRaider Offline
I'd put in junkyard bulbs cause Im a cheapskate. smile It wont hurt to drive with say the left turn signal indicator pulled out for sure.
Re: Bulbs behind the 4x4 and warning lights [Re: Schoeny] #1041404 02/03/12 09:29 PM
Angelo Offline
I changed them years ago. Can't recall the whole process but it was easy once the cover came off. I bought replacement bulbs from radio shack. You'll either have to reuse the color covers that go on the originals or replace. Like I said, can't recall the process exactly, did it 6-7 years ago.
There may be a write up some place or someone with the knowledge. I'd like to refresh my memory myself.
Does anyone know how to replace the bulbs behind the ac/heat unit?
Re: Bulbs behind the 4x4 and warning lights [Re: Angelo] #1041405 02/03/12 09:53 PM
Schoeny Offline OP
Yeah, I found the directions to do it in the FAQ, but it still doesn't bring up the size. I think I'm leaning towards pulling one out, re-assembling just enough to make it drive-able with the gauges working, then going and finding them at either a Radioshack or a parts store.
As for the lights behind the AC/heater, if you do find a source, please let me know as that is one of my next tasks after this and the select-trac blinking. <img src="/forums/images/graemlins/smile.gif" alt="" />
1995 Montero LS
Re: Bulbs behind the 4x4 and warning lights [Re: Schoeny] #1041406 02/03/12 10:07 PM
TheViper Offline
i dont think your going to find those bulbs very easily...alot of parts stores i tried said they have the correct size only to find out the bulbs dont fit.
My solution after searching was to go to a pick-n-pull and pull as many bulbs out of old monteros i could
also i ran the monty with a couple bulbs out to show the parts store and everything was fine
1995 Montero SR
Re: Bulbs behind the 4x4 and warning lights [Re: TheViper] #1041407 02/03/12 11:21 PM
Clem1 Offline
I got mine at O'Reilly. I think the Sylvania part number is 74. I just asked the counter guy to look it up in their computer. Like others have said it was a little large, but it worked.
HTH
Clem
1999 Mitsubishi Montero (Winter Package)
Re: Bulbs behind the 4x4 and warning lights [Re: Clem1] #1041408 02/03/12 11:54 PM
TheViper Offline
HTH
Clem
I think the 74 is what they tried to give me, but the bulb was too fat to fit back into the little black socket...if you got that too fit thats pretty awesome <img src="/forums/images/graemlins/confused.gif" alt="" />
1995 Montero SR
Re: Bulbs behind the 4x4 and warning lights [Re: TheViper] #1041409 02/04/12 12:31 AM
HTH
Clem
Grasscat knows which ones fit. The ones behind the compass however are mitsu only bulbs.
I think the 74 is what they tried to give me, but the bulb was too fat to fit back into the little black socket...if you got that too fit thats pretty awesome <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Bulbs behind the 4x4 and warning lights [Re: off-roader] #1041410 02/04/12 02:09 AM
Grasscat Offline
1998 Mitsubishi Montero Car Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 1157
Front Turn Signal Light Bulb Size: 1157
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 2057
Stop Light Bulb Size: 2057
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: H3-55W
License Plate Light Bulb Size: 5008
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 1157
Rear Sidemarker Light Bulb Size: 168
Ash Tray Light Bulb Size: 74
Step/Courtesy Light Bulb Size: DE3022 or DE3175
Trunk/Cargo Area Light Bulb Size: DE3175
Instrument-General Light Bulb Size: 158 Or 74
Michael j
TreadLightly! Trainer
Re: Bulbs behind the 4x4 and warning lights [Re: Grasscat] #1041411 02/04/12 02:37 AM
TheViper Offline
Are those compatiable with the Gen 2? Are those mitsu part #s?
1995 Montero SR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6440 MB (Peak: 0.7701 MB) Data Comp: Off Server Time: 2026-06-07 09:08:03 UTC
