6G72 DOHC 1993 Has anyone tried to transplant one into a Montero. #1041436 02/04/12 07:56 AM
Rayman Offline OP
The engine is in a Dodge Stealth 1993. It's a 24 valve 3000cc they only made it for 3 years just wondering if it tranplants into a 1995 LS Montero. Does it have a crank sensor?
Ray
In the Pacific Wonderland
95 Montero 5 spd
87 Raider 2.6 5 spd
65 MG Midget
2002 Integra GSR (wife's car)
Re: 6G72 DOHC 1993 Has anyone tried to transplant one into a Montero. [Re: Rayman] #1041437 02/04/12 10:09 AM
TainterRacing Offline
An 95 SR has a 6g74 DOHC motor stock......Are you asking about the trubo 3.0? I am sure it could bedone if it ha not been done.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: 6G72 DOHC 1993 Has anyone tried to transplant one into a Montero. [Re: TainterRacing] #1041438 02/04/12 06:43 PM
ryany Offline
The SOHC 24 valve 3.0 engine (along with the SOHC 12 valve 3.0 and the DOHC 24 valve 3.5) was available from Mitsubishi in some of the Gen II Monteros, although it's somewhat rare. The engine should be able to be transplanted without too much difficulty (plus you'd be able to use all factory parts), although the wiring harness would need some modifications.
95 Montero SR
Re: 6G72 DOHC 1993 Has anyone tried to transplant one into a Montero. [Re: ryany] #1041439 02/06/12 05:36 PM
MBrannon Offline
One of the things on my bucket list is to swap a 3.0 twin turbo motor in from a 3000GT or Stealth. I've been planning to do this for a few years now but have been too busy! At this point I will probably wait until I buy a nice SR.
It really won't be too hard. The biggest obstacle will be to wire in the TCU into the TT wiring harness to operate the ATX. I've done this on two occasions in other Mitsubishis but never on a Montero.
The 93 Stealth non turbo motor has a crank sensor which is used to fire the coil packs. (technically it sends the signal to the ecm and then mfi to fire the coil packs). The 91-99 6g72 DOHC motors are all very similar. The 91-92's had a different cam sensor that can be used to manually to adjust timing. This can be wired in fairly easily to the 93-99 motors. The 93-99 turbo engines had stronger main girdles that do not become a factor until 700+ HP.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6582 MB) Data Comp: Off Server Time: 2026-06-07 06:09:49 UTC
