removing my tranny A340H #1041440 02/04/12 05:49 PM
djordan6319 Offline OP
I have looked all over and i can not find what all i have to remove to take tranny out All i am doing is replacing the flywheel if anyone can help or has any info please let me know
Thanks
Re: removing my tranny A340H [Re: djordan6319] #1041441 02/06/12 02:14 AM
kewlynx Offline
You have already been pointed to manual sources in your other posts. Use them.
A 17mm toggle socket and 24" extension for the top bolts are helpful.
**ubi apis- ibi salus**
Re: removing my tranny A340H [Re: kewlynx] #1041442 02/06/12 05:58 AM
I have looked at the manuals and they are no help at all they only show how to take the tranny apart not how to remove I have looked through them many times and havn't seen anything that shows the removal of the tranny
Thanks for the info on the socket and extension
Re: removing my tranny A340H [Re: djordan6319] #1041443 02/06/12 03:26 PM
G
Greg_Canada Offline
Disconnect everything, unbolt the drive shafts (mark where they are to go back) undo bolts, remove tranny?
Def. want to use a tranny jack...
89 4Runner
Re: removing my tranny A340H [Re: Greg_Canada] #1041444 02/06/12 06:31 PM
that is what i thought i just wanted to make sure there wasn't anything special that needed to be done I have never removed a toyota tranny do you know about how much it weighs?? i have to buy a tranny jack want to make sure it will hold LOL
Re: removing my tranny A340H [Re: djordan6319] #1041445 02/07/12 02:33 AM
kewlynx Offline
Go rent one and get under there with a flashlight and figure it out.
Re: removing my tranny A340H [Re: kewlynx] #1041446 02/07/12 03:10 PM
Oh thanks <img src="/forums/images/graemlins/kewl.gif" alt="" /> kewlynx i am sooo glad that you are a smartass i am sure that you can take your suggestions and your flashlight and stick straight up your ass.. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: removing my tranny A340H [Re: djordan6319] #1041447 02/07/12 03:43 PM
O
oldsub86 Offline
Don't be mean.
You asked for help and you got some.
There is nothing really complicated about removing the transmission. You just unbolt everything that needs to be undone in order to get it loose from the engine and the truck.
It is a bit more difficult to put back in as you have to get it lined up.
You need to remove the shifters from inside.
You need to disconnect wiring from the transmission under the truck. You should start by disconnecting the battery too.
You will need to lift the truck a bit but not a whole lot. Make sure you have it securely on jack stands so you don't kill yourself.
You will need a transmission jack. I used one of the scissor style units as I did not have enough height to permit the use of one of the adaptors that sits in the saddle of the floor jack. I did not want to lift the truck that much.
The transmission and the transfer case come out as one unit. It is very heavy and off balance so be careful. You do not want to attempt it without a transmission jack and it needs to be tied to the jack so it cannot fall on you.
Remove all of the bolts from the bellhousing, or at least loosen all of them and leave a couple in until you are ready to actually remove the transmission. As already noted a flex socket and a long extension are going to be needed for the upper bolts as there is not a whole lot of space in there.
Once you have most of the stuff loose - but the bolts not all removed, support the transmission and then remove the rear crossmember that holds the back of the transmission.
You will have removed the drive shafts, front and back by then and hopefully you remembered to mark them so you can put them back as they came out. I normally wipe them off and then spray a line on the unit with a paint can before removing them. An orange or white stripe will show you how they go back together. Some people will mark them with a punch etc. To each his own.
After the cross member comes off and you have removed the last bolts on the bell housing you should be able to wiggle the transmission back and then once the input shaft is clear of the clutch, lower it down. At this point, I had to then slide the transmission off of the jack in order to get enough clearance to drag it out from under the truck.
You will then be able to get at the flywheel.
Let me suggest that you have a good look and replace anything else in the clutch setup that needs it now as taking this thing apart often is not my idea of fun. I have had the transmission out of our 95 4Runner 3 times. If the clutch is worn, do yourself a favour and put a new one in. Get one from Toyota. I had no luck with aftermarket kits and that is one of the reasons for my having it apart so many times.
If you are feeling poor and the pressure plate looks reasonable and is flat, you might get away with just the clutch disk itself. Get one from Toyota! They are not expensive. I would also at a minumum replace the throw out bearing and the bearing in the end of the crank. Find a wooden dowel that fits it tight - fill the hole with grease - then pound the dowel into the grease and the bearing will come out. Gently tap the new one in using a socket of the right size.
If you pull the pressure plate off, which you will I guess if you are going to swap out the flywheel, then you will need an alignment tool to put it back correctly so you can get the input shaft back into the hole.
When you are ready to put it back in, make yourself some alignment dowels from bolts with the heads cut off. I got the right sized bolts from some place like Home Depot and cut the heads off and cut slots for a screwdriver (so I could get them out again) and then put them in a hole on each side of the engine to help align the bellhousing when the transmission goes back in. Get 2 helpers to put it back. One to lay under the front and tell you when it is lined up or help shift it into place and one of you on either side of the transmission further back to work the jack for lift and to wiggle the thing back into place. As I said, with the transfer case hanging on one side it is not evenly balanced and thus needs to be helped into place.
Once the transmission is back in place, it is a simple matter of replacing everything you removed or disconnected.
It is heavy. Be careful.
There is also this
http://www.4x4wire.com/toyota/4Runner/maintenance/clutch/
and although it relates to a newer vehicle, it is essentially the same.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: removing my tranny A340H [Re: oldsub86] #1041448 02/07/12 05:01 PM
yes I realize that i got some info that i can use and i am thankful for that however I have never messed with a Toyota tranny and couldnt find anything on the removal of the tranny I didn't know if there is a certain way that you needed to remove this tranny or if it would be just like any normal tranny Sorry that you took offense to my post and Thank you very much for giving me the info that i was looking for..just so you know i will not be posting anymore on this fourm because of the reply that was givin from a moderator Thank you again for the info i was looking for
Re: removing my tranny A340H [Re: djordan6319] #1041449 02/07/12 05:43 PM
G
Greg_Canada Offline
Bud you cant talk like that to people here... this isn't pirate.... many of your past posts have been rude and we're still helping you out. Now i bet it's a translation thing from real life to typing (some things just come out wrong / were meant to be jokes but don't come out that way).
No one is trying to be a douche here, but seriously it's as easy as grabbing a flashlight and figuring out what to do...
89 4Runner
Moderated by  4x4Wire, Mudraider
PHP: 7.4.33 Page Time: 0.589s Queries: 16 (0.586s) Memory: 0.6438 MB (Peak: 0.7754 MB) Data Comp: Off Server Time: 2026-06-10 01:52:43 UTC
