radiator fans for 88 Raider? #1041558 02/07/12 02:06 PM
bar2hunter Offline OP
Is there a direct correlation between the dual radiator fans and the A/C on an 88 Raider? My fans are not working. So, should I be concerned when running the A/C? I'm in Texas and need the A/C more often than not! <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: radiator fans for 88 Raider? [Re: bar2hunter] #1041559 02/07/12 04:03 PM
Kevin C Offline
The small electric fan in the front should come on with the AC compressor. Often the brushes wear out. I replaced mine with a generic that I bought from Summit Racing. It was the same sized fan and I modded the original shroud to get it to bolt in.
Also check your evaporator (under the dash). It can get clogged with pet fur and leaves over the years and reduce your AC's output.
Kevin
Re: radiator fans for 88 Raider? [Re: Kevin C] #1041560 02/07/12 07:24 PM
LandRaider Offline
Also check your evaporator (under the dash). It can get clogged with pet fur and leaves over the years and reduce how well your AC works.
Kevin
When I got the AC up and running in my 4.3 truck, I pulled the evaporator out, and it was filthed up with mud, and dirt, and leaves. It was like a compost pile in there.
Re: radiator fans for 88 Raider? [Re: Kevin C] #1041561 02/07/12 07:31 PM
The small electric fan in the front should come on with the AC compressor. Often the brushes wear out. I replaced mine with a generic that I bought from Summit Racing. IT was the same sized fan and it modded the original shroud to get it to bolt in.
Kevin
Thanks!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: radiator fans for 88 Raider? [Re: LandRaider] #1041562 02/07/12 08:02 PM
Kevin C Offline
Kevin
I think mine had too much dog fur to really be an effective composter.
Re: radiator fans for 88 Raider? [Re: Kevin C] #1041563 02/08/12 02:16 AM
conner Offline
I replaced mine with a generic that I bought from Summit Racing. IT was the same sized fan and it modded the original shroud to get it to bolt in.Kevin
Word of caution. The majority of these universal fans have to be wired to your plug. if you are not careful and reverse the wiring, the fan will work ,but turn in the wrong direction and render it useless.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6124 MB (Peak: 0.6832 MB) Data Comp: Off Server Time: 2026-11-03 04:53:14 UTC
