'89 4Runner Fuel line replacement? #1041943 02/12/12 08:58 PM
P
Pyroboy Offline OP
I have to swap out a leaking fuel tank in my 4Runner. The fuel lines were replaced in 2001 after a rust problem (it is an Ontario truck). I was thinking that I will likely have more problems when i swap the tank so I thought of switching them out to flexible line with AN fittings. Just wondering if anyone has done this and what was required so I can get the parts before I tear into it. Also, any reason why I should not do this?
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: '89 4Runner Fuel line replacement? [Re: Pyroboy] #1041944 02/16/12 03:35 AM
kewlynx Offline
Why you shouldn't would be if they still look serviceable.
I'm thinking where you might want to be looking is where you transition from the tank to the fuel filter to make sure your fittings would be work, or find a place to place a fitting to bring back to the original line.
I'm seeing alot of stuff out on Jeg's website that would be possible to use.
Where you actually might run into trouble is buggering the wiring harness to your tank pickup. If not replacing it, you'll at the very least need to pick up a new gasket and the screws to swap it over.
I can't remember the last year they quit putting drain plugs on the tanks; if you've got one, you can see it thru the aft end of the skid plate; 17mm.
Last, the older 4R's had an access panel under the RR pax seat to let you get to the tank fuel pump; give a look before you start; if lucky, it'll save some more hassle.
**ubi apis- ibi salus**
Re: '89 4Runner Fuel line replacement? [Re: kewlynx] #1041945 02/17/12 07:07 AM
P
Pyroboy Offline OP
Thanks. My first thought was to release the fuel pump / sender unit from the tank then drop the tank without moving the rest but I'll see how that goes. Do you know what the tube size / threads are for the stock line? Mine looks to have been replaced with hand-bent stock as the Toy parts were too expensive at the time.
I have the underseat access hatch and a tank drain so that will help make it a bit simpler.
22RE, 5-spd.
Re: '89 4Runner Fuel line replacement? [Re: Pyroboy] #1041946 02/17/12 08:54 AM
kewlynx Offline
Sure don't. I wonder if the material specs are linked to the part number if the dealer looks it up for you.
Nice to know you have the tank access in that generation.
Re: '89 4Runner Fuel line replacement? [Re: kewlynx] #1041947 02/17/12 04:48 PM
stock87 Offline
Keep in mind the 4Runners stayed the old body style 1 year past the pickups. the first 4 door hardtop 4Runner was the 1990 model year.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: '89 4Runner Fuel line replacement? [Re: Pyroboy] #1041948 02/24/12 03:01 AM
Adam F Offline
Good luck getting the bolts out of the sending unit without breaking them. Ive never had any luck.
97 4R, stock, daily driver
Re: '89 4Runner Fuel line replacement? [Re: Pyroboy] #1041949 03/05/12 08:56 AM
KiwiCowboy Offline
I believe the fittings will be 10-1.0mm. Just use a hex bolt to verify it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6187 MB (Peak: 0.7096 MB) Data Comp: Off Server Time: 2026-07-10 19:20:16 UTC
