98 Gen 2.5 CEL Code P0421 #1042018 02/15/12 03:11 AM
O
OneTime Offline OP
I have a CEL light on with a code P0421. I remember the dealer telling me a while back it was either the #1 or the #2cat, I cant remember which. I pulled the code again at autozone and was given the P0421 "warm up catalyst effeciency below threshhold" Do I simply need to replace one of the cats or is something else going on?
98 Gen 2.5 w/ winter package & 31x10 BFG ATs.
Re: 98 Gen 2.5 CEL Code P0421 [Re: OneTime] #1042019 02/15/12 05:09 AM
Thats a code for:
"Basically this means that the oxygen sensor downstream of the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system."
I found a cheap fix that works on a 3g Eclipse, and may work for you at this site.
Also check for leaks in the exhaust system ahead of the final ohtwo sensor on bank 1. May be a bad ohtwo sensor too...
Re: 98 Gen 2.5 CEL Code P0421 [Re: fasteddy] #1042020 02/17/12 05:04 AM
O
OneTime Offline OP
Is there anyway for a mechanic to find out if the cat is bad or if its the O2 sensor?
Re: 98 Gen 2.5 CEL Code P0421 [Re: OneTime] #1042021 02/17/12 06:14 PM
If the cat is bad the inlet and outlet temperatures will be vey close to the same. If it's good, the outlet temps will be higher than the inlet. Use a non-contact thermometer to check. Harbor Freight sells them.
Re: 98 Gen 2.5 CEL Code P0421 [Re: JohnnyBfromPeoria] #1042022 02/17/12 07:46 PM
O
OneTime Offline OP
So if the temps are different, then I should start with replacing the 02 sensor?
Re: 98 Gen 2.5 CEL Code P0421 [Re: OneTime] #1042023 02/18/12 04:36 AM
diagnose first, throw parts at it after. This saves $$$$$....
The ohtwo sensor can be tested...
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6098 MB (Peak: 0.6797 MB) Data Comp: Off Server Time: 2026-07-15 02:51:59 UTC
