Re: Three red lights on dash? [Re: sasnydley] #1042098 10/10/12 07:16 AM
Skjeflo Offline OP
Just for the archives.
Things I've done to track this down:
-Checked and cleaned grounds, everyone I could track down.
-Cleaned wire connections.
-Replaced the battery (it was a bit dodgy in tests).
-Removed and had alternator tested (good, at that time).
The three lights finally came on and would not go out, like 1/2 power (as described by Schoeny). With the lights like this the volt meter would wander from 14+ volts down to around 11 and then back up. Eventually (two days after the lights came on solid, no flicker of on/off) the gauge just kept dropping.
Pulled alternator again (hood up to alt. out in 12 minutes - got down which two socket sizes I need now!) and this time failed test.
So, clean grounds and contacts, fresh battery and alternator and problem solved! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Mark
97 Montero
90 4-Door Montero RS -- R.I.P.
Re: Three red lights on dash? [Re: Skjeflo] #1042099 10/11/12 02:37 AM
Toja so. Only time I got a dim alt light was when the alternator was starking to fail.
Re: Three red lights on dash? [Re: fasteddy] #1042100 10/11/12 07:15 AM
LandRaider Offline
Nothing helpful to add here, but..
https://www.youtube.com/watch?v=EAdGhMRBbzY
Re: Three red lights on dash? [Re: LandRaider] #1042101 10/12/12 04:13 AM
Skjeflo Offline OP
So THATS what my problem was! I thought there were five lights.
Well, someone told me once that there were...but I don't talk about that time in my life much.
<img src="/forums/images/graemlins/pfft.gif" alt="" />
Seriously, thanks to all for the ideas.
97 Montero
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6103 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-06-07 04:48:20 UTC
