Gen 1 sunroof drain line locations?
#1042170
02/16/12 07:23 PM
I got under the Montero today and tried to find the sunroof drain lines, but the only line I could find was behind the passenger side rear wheel, attached to a cross member. I couldn't quite see where exactly it goes, so I'm not sure its the right line -- maybe a diff breather? Anyone have a good description of the lines or a pic to help me find them?
Third times a charm.
Re: Gen 1 sunroof drain line locations?
[Re: seely]
#1042171
02/17/12 02:28 AM
I sure we can help, but it would be nice to know what Montero you have.
Michael j
TreadLightly! Trainer
[Re: seely]
#1042172
02/17/12 03:37 AM
If you have a 4 door, you likely found 1 of the 4. Look for one on the other side, same local. There is one in each of the 4 corners of the drain pan that surrounds the glass. I believe the front drains go down the piller between the doors. You may succeed in clearing these by running a siff wire through them from the bottom ends.
[Re: tdf46]
#1042173
02/17/12 03:43 AM
Thanks, I wasn't sure how many there were... I looked on the other side of the one I may have found, but didn't see anything similar on the other side. I'll check the B pillars and see what I can find.
[Re: seely]
#1042174
02/17/12 04:33 AM
Check the A-pillar, too...look inside the fender?
