Gen 1 sunroof drain line locations? #1042170 02/16/12 07:23 PM
seely Offline OP
I got under the Montero today and tried to find the sunroof drain lines, but the only line I could find was behind the passenger side rear wheel, attached to a cross member. I couldn't quite see where exactly it goes, so I'm not sure its the right line -- maybe a diff breather? Anyone have a good description of the lines or a pic to help me find them?
Third times a charm.
Re: Gen 1 sunroof drain line locations? [Re: seely] #1042171 02/17/12 02:28 AM
Grasscat Offline
I sure we can help, but it would be nice to know what Montero you have.
Michael j
TreadLightly! Trainer
Re: Gen 1 sunroof drain line locations? [Re: seely] #1042172 02/17/12 03:37 AM
tdf46 Offline
If you have a 4 door, you likely found 1 of the 4. Look for one on the other side, same local. There is one in each of the 4 corners of the drain pan that surrounds the glass. I believe the front drains go down the piller between the doors. You may succeed in clearing these by running a siff wire through them from the bottom ends.
Re: Gen 1 sunroof drain line locations? [Re: tdf46] #1042173 02/17/12 03:43 AM
seely Offline OP
Thanks, I wasn't sure how many there were... I looked on the other side of the one I may have found, but didn't see anything similar on the other side. I'll check the B pillars and see what I can find.
Re: Gen 1 sunroof drain line locations? [Re: seely] #1042174 02/17/12 04:33 AM
Check the A-pillar, too...look inside the fender?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-05-30 00:52:44 UTC
