need some help with the yota..... #1042258 02/17/12 09:09 AM
W
workman11 Offline OP
i have a 81 toyota truck with a 22r in it. i am wanting to lift it and eventually put bigger tires on. it doesnt have a ton of power obviously so was wondering what you guys thought on size. i am thinking like 5" lift and maybe 33's? and i have heard that mixing body and suspension lift isnt a great idea. i am thinkin 5 suspension and if down the road i wanted to raise it a couple more inches that i dont want to buy whole new set up. just a thought. got big plans for it in my head will see what showes up in real life....
Re: need some help with the yota..... [Re: workman11] #1042259 02/17/12 10:31 AM
W
or possibly shackles? i dont know much about all the techy stuff. i can get stuck and unstuck but i needs some advice before i spend money. want to make sure what i buy is what will work for what i do. muddin a little crawlin just general wheelin.
Re: need some help with the yota..... [Re: workman11] #1042260 02/20/12 01:19 AM
P
Pyroboy Offline
You should post on the Toyota board. What gears do you have? A small body lift is alright but I wouldn't go over 2", personally. There are some nice kits on 4crawler.com.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: need some help with the yota..... [Re: Pyroboy] #1042261 02/20/12 04:43 AM
kewlynx Offline
Moderator for this section notified for move.
Otherwise, welcome to the Wire!
**ubi apis- ibi salus**
Re: need some help with the yota..... [Re: kewlynx] #1042262 02/23/12 10:56 PM
Jim_Paget Offline
Just went through a issue with a jeep tub on which the prior owner had installed a 3" body lift. Suffice to say that the tall body lift put too much strain on the body mounts on the tub. Six of the ten had to be completely rebuilt.
I would be very leery of a tall body lift.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: need some help with the yota..... [Re: workman11] #1042263 03/20/12 06:57 PM
Cochip Offline
Honestly 33's and a five inch lift is a bit much for such a low hp engine. I'm not sure what your plans are for your truck, but I'd keep the lift to 2-3 inches and run some 31's. The engine is still gonna struggle on hills and your gas milage will suffer, but it won't be as bad. As far as adding a body lift to 5 inches of suspension lift, again I wouldn't recommend it. A seven inch lift with 33's and an engine that puts out under a 100 hp. Unless you plan on re-gearing your really going to be crawling along. Especially on a nice windy day. My 2 cents.
Re: need some help with the yota..... [Re: Cochip] #1042264 03/20/12 10:02 PM
G
Greg_Canada Offline
a 2.5" OME suspension lift would work great with 33" tires, add a small bodylift if you need more.
My 3" BL is fine on my truck, i even rolled it (low speed) 5 years ago, no problem with the mounts.
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6167 MB (Peak: 0.6907 MB) Data Comp: Off Server Time: 2026-07-10 18:18:29 UTC
