Head light dimmer switch is slow to work #1042300 02/18/12 07:45 AM
Bent_85 Offline OP
My 91 truck. After my truck sits overnight the high beam does not work. Only after warming up 15 min or so does the high beam for the head light start to work. I think there is a relay in the fuse box under he hood. Is there another relay elseware that might be acting up? Thx
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Head light dimmer switch is slow to work [Re: Bent_85] #1042301 02/19/12 03:04 AM
P
Pyroboy Offline
Check the 'sticky' threads at the top of this board for the FSMs. Should be a wiring diagram in there somewhere.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: Head light dimmer switch is slow to work [Re: Bent_85] #1042302 02/19/12 06:56 PM
4Crawler Offline
No relay for the high beams, likely just dirty contacts on the headlight combo switch:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#Headlight_Combo
The relay under the hood just supplies power for the headlights, low and high beams.
Re: Head light dimmer switch is slow to work [Re: 4Crawler] #1042303 02/20/12 08:17 AM
Bent_85 Offline OP
I have cleaned the flip / dimmer & signal light / column switch behind the steering wheel. I had gotten one from PnP expecting my contacts to be dirty. I dragged some sand paper though the contacts + filed them. I was carefull when I put it back together. So fairly sure that it can't be that switch. On the canadian pages in the posted link I "think" see a headlight dimmer switch relay under the hood. Working nights now so I will check it out tomorrow.
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Head light dimmer switch is slow to work [Re: Bent_85] #1042304 02/20/12 05:28 PM
4Crawler Offline
If you have the DRLs, there is a dimmer relay that is used as part of the DRL system:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#DRL
As I understand it, there is a big power resistor that is in-line with the headlights during daytime operation then when you actually turn on the lights, that relay turns on and shorts out the resistor (bypassing it) to give you full brightness on the headlights. That should be the separate from high or low beam operation. But I'm not at all familiar with the Canadian headlight wiring setup, especially on the early '90s models.
Re: Head light dimmer switch is slow to work [Re: 4Crawler] #1042305 02/21/12 02:31 AM
CJM Offline
yep you are correct , "back in the day" there was a Canadian recall for DRL , and a headlamp reduction wire was installed at the dealer .. recall might sitll be online somewhere . I believe it was a voltage reduction wire .. but just going by memory
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6145 MB (Peak: 0.7010 MB) Data Comp: Off Server Time: 2026-05-29 15:34:07 UTC
