T100 power door lock weak #1042449 02/21/12 05:50 PM
jmoser Offline OP
The power door lock on driver's side is weak - does not always click shut and I often have to push the lever down by hand half way. happens when starting the engine normally but Bigger concern when locking with the remote keyfob - always have to check the handle to be certain.
Is this a solenoid going bad or maybe just need some lube in there?
Don't want to pop off the door panel if I don't know what to look for.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: T100 power door lock weak [Re: jmoser] #1042450 02/22/12 04:05 AM
BamZipPow Offline
It's probably the motor brushes. The motor can be rebuilt if you have the skills/tools. Seems one can use the carbon brushes they use fer slot cars in the window motors. Give it a shot, take some piccies, and post them up. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: T100 power door lock weak [Re: BamZipPow] #1042451 02/23/12 09:48 PM
G
Greg_Canada Offline
Happened to my 99 4runner, i replaced the door latch/motor asembly with a good used unit...
89 4Runner
Re: T100 power door lock weak [Re: jmoser] #1042452 02/24/12 05:27 AM
kewlynx Offline
Clean your window switches while you have it torn down also. <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: T100 power door lock weak [Re: Greg_Canada] #1042453 02/27/12 04:28 AM
jmoser Offline OP
Anyone know if the 96 T100 is compatible with other Models for the door lock motor? 4runner maybe?
Jeff
Re: T100 power door lock weak [Re: jmoser] #1042454 02/28/12 08:53 AM
BamZipPow Offline
I would guess the motor is the same... <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6120 MB (Peak: 0.6816 MB) Data Comp: Off Server Time: 2026-10-24 23:55:09 UTC
