Switch to synthetic... better pressure, but now burning a bit?
#1042479
02/22/12 01:56 AM
I gave the Monty it's first oil change under my care, and went to Mobile 1 5w30. I've used Mobil 1 in other higher mileage vehicles (this has 160k) and had good results. I was pleased to see my oil pressure is much stronger, but now when I take off from the first few stop signs, before the engine is totally warmed up, I get a nice puff of blue smoke that I never did before with the used up dino oil. I'm not *too* concerned -- it goes away once the engine hits operating temp, but I'm a little uneasy it just started all the sudden after the oil change.
Third times a charm.
Re: Switch to synthetic... better pressure, but now burning a bit?
[Re: seely]
#1042480
02/22/12 02:14 AM
I run 10w30 in my trucks, even a rebuilt motor I run 10w30. I would suspect valve seals are whats causing the smoke. not a big deal. 7 years of driving my own personal fog machine and zero problems. I fixed it just because I got tired of the cloud while offroading.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#1042481
02/22/12 02:16 AM
I run 10w30 in my trucks, even a rebuilt motor I run 10w30. I would suspect valve seals are whats causing the smoke. not a big deal. 7 years of driving my own personal fog machine and zero problems. I fixed it just because I got tired of the cloud while offroading. Yep. Mosquito-bishi was what they used to call mine on the trail. <img src="/forums/images/graemlins/lol.gif" alt="" /> Try a nice Rotella diesel 15w40 until you do them valve seals someday...
[Re: StockRaider]
#1042482
02/22/12 02:23 AM
Just out of curiosity, what's your oil pressure usually read, if you know?
Thanks for the reassurance. I'm not too concerned, just thought it was odd to change the oil and instantly start having this issue.
[Re: seely]
#1042483
02/22/12 02:42 AM
90psi cold, 60psi running @3krpm, 20-30 idle warm with a mechanical gauge. 0-30 on the factory gauge at all times.
[Re: StockRaider]
#1042484
02/22/12 04:43 AM
Great, thanks -- sounds about where I am roughly as well.
[Re: seely]
#1042485
02/22/12 05:30 AM
Drain the synth. Refill with 10w40 diesel dino oil plus a quart of dexron and run it for a couple hundred miles. Drain and refill with synth and report back.
Synth leaks easier than dino, so it goes past ALL seals and gaskets easier. The dexron will soften and swell the seals some which will delay the need to do a top end teardown. An added benefit is the high detergent level in the dexron which will clean some of the crud and sludge out.
[Re: fasteddy]
#1042486
02/22/12 05:38 AM
An added benefit is the high detergent level in the dexron which will clean some of the crud and sludge out. Boy will it ever. Just don't leave it in too long. Rotella T synthetic is good stuff. I use the non-energy conserving stuff in my motorcycle (better for the wet clutch) and occasionally the regular synthetic in my '95, although I'm partial to Mobil 1. BTW, my '95 does not smoke at 185K miles on the stock heads and valve guides/seals. John B.
[Re: fasteddy]
#1042487
02/22/12 06:11 AM
Synth leaks easier than dino, so it goes past ALL seals and gaskets easier. The dexron will soften and swell the seals some which will delay the need to do a top end teardown. An added benefit is the high detergent level in the dexron which will clean some of the crud and sludge out. I have often wondered that about the dexron, my rear main starting leaking the last week think this might be a good way to get a few more months out of it?
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
[Re: boostin]
#1042488
02/22/12 06:25 AM
Many of the high mileage motor oils have extra seal swelling compounds. Mobil high mileage synthetic has extra detergent to help clean the motor out.
