v6 might max fan shroud #1042643 02/23/12 06:57 PM
joey_crandall Offline OP
if i do end up keeping the truck im gonna need a new fan shroud, any body know of one that will work. the 4 cylinder might maxs ahve the lower hose on the oposite side and the fan shroud looks smaller, and i just read that monty radiators are taller and wider, so does anyone have a fan shroud i need or know of universal type that will work.
Re: v6 might max fan shroud [Re: joey_crandall] #1042644 02/23/12 09:36 PM
P
PhantomSky2 Offline
need a 2.6 shroud myself..
Re: v6 might max fan shroud [Re: PhantomSky2] #1042645 02/23/12 10:39 PM
those are easy to find. theres probably a couple on eaby
Re: v6 might max fan shroud [Re: joey_crandall] #1042646 02/23/12 10:46 PM
RECON45 Offline
Is there a difference between the montero and mighty max fan shrouds? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: v6 might max fan shroud [Re: RECON45] #1042647 02/23/12 10:49 PM
Not sure but you can use Mitsu ASA to check using vin's.
Re: v6 might max fan shroud [Re: off-roader] #1042648 02/24/12 12:31 AM
i was reading in a post earlier today that monero radiators are taller and narrower, and russel (rxinhed) said something about it nor fitting when i bought parts from him a while ago
Re: v6 might max fan shroud [Re: joey_crandall] #1042649 02/24/12 01:35 AM
boostin Offline
as far as i know, well at least up here in canada where v6 mm practically dont exist, the only mm that had fan shrouds are models with ac, so they are rare in there own.
You can do what i did, Electric fan, would not trade it for the world, Better MPG, more power and for us carbed 2.6 guys much faster warm ups in the winter plus makes the front of the engine more tidy
I have developed a very economical fan kit using OEM pnp parts that will work as good as a factory one, no cheesy am stuff that always brakes.
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: v6 might max fan shroud [Re: boostin] #1042650 02/24/12 02:27 AM
Joey,
Send me a picture of the radiator. The 4-cyl Montero and MM radiators are physically very different, but I have not been able to compare the V6 model. Have you check versus a Starquest piece?
R-
Re: v6 might max fan shroud [Re: rxinhed] #1042651 02/24/12 04:04 AM
TainterRacing Offline
A starquest is shorter and wider then the montero.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6280 MB (Peak: 0.7156 MB) Data Comp: Off Server Time: 2026-06-07 04:48:44 UTC
