Page 1 of 4 1 2 3 4
useing turbo block with out turbo, what needs to be changed? #1042684 02/24/12 05:44 PM
goobuds Offline OP
so i have found me a couple of good blocks all from turbos. and need help. i need to know well i have anyproblem useing a oil pump from the non turbo. and is there anything i have to do, i plan on putting new piston and rings bearings, t-kit. putting it in my 88 raider. useing non turbo head not sure if theres a differance. i just need to know what i can and cant use please and thank you to all.
oh i picked 3 block up one is all stock two have had bs kits and ones been boared. how much did i pay 125
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: useing turbo block with out turbo, what needs to be changed? [Re: goobuds] #1042685 02/24/12 06:13 PM
Kevin C Offline
No problem on using the non turbo pump and pickup. If you have the cranks from the turbo motor's they are hardened and a lot tougher.
The turbo blocks will have oil jets to cool the bottoms of the pistons. You can leave them in without any issues.
The main difference on the turbo heads is that they used stellite faced exhaust valves. Some Montero 4 cyl motors did as well. If you dont have them, it's a nice upgrade.
BTW- magna flux the blocks deck before you machine them.
Sounds like a good find.
Re: useing turbo block with out turbo, what needs to be changed? [Re: Kevin C] #1042686 02/24/12 06:30 PM
goobuds Offline OP
http://seattle.craigslist.org/tac/pts/2868169912.html
ok here is some photos from the guys post getting ready to pick them up
Re: useing turbo block with out turbo, what needs to be changed? [Re: goobuds] #1042687 02/24/12 06:37 PM
Kevin C Offline
Grab it all... Time to build a turbo 2.6. <img src="/forums/images/graemlins/smile.gif" alt="" />
Make sure the cranks are not in too bad shape.
Re: useing turbo block with out turbo, what needs to be changed? [Re: goobuds] #1042688 02/24/12 06:41 PM
TainterRacing Offline
All most looks like forged pistons on the one. Hard to tell tho to small.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: useing turbo block with out turbo, what needs to be changed? [Re: TainterRacing] #1042689 02/24/12 07:27 PM
goobuds Offline OP
yes i know i will probley just get one running n/a for now since i really miss driving my raider not to mention the geo storm gsi iam driveing right know is do well over due for the junker 260,000 miles with only a t-belt and plugs and wires. i am ready to build. hehe
also picked up a lower skid plate, wiper arm and the little cubby hole for the midddle console yester for 10 bucks. i had them once before. but hey they got lost when i got traded the raider then got it back long storie anyways thing are looking good. well let every one know what goes on as i am sure i will have more question never have rebuild the lower ends on the 2.6.
Re: useing turbo block with out turbo, what needs to be changed? [Re: Kevin C] #1042690 02/24/12 08:33 PM
joey_crandall Offline
SQ's also have different valave seats to i think, and different water pump, the sq water pump has fitting for a hose that wrpas around the back of the engine.
Re: useing turbo block with out turbo, what needs to be changed? [Re: joey_crandall] #1042691 02/24/12 08:43 PM
P
PhantomSky2 Offline
My monty has that and its a n/a block...its for the heater core.
Re: useing turbo block with out turbo, what needs to be changed? [Re: goobuds] #1042692 02/24/12 09:09 PM
Shooter Offline
Wow! Great Find!
Proud owner of Dark Blue 1988 Dodge Raider G54B 4cyl. Dealer owned and Sat on showroom floor in Austin Texas until 2003! Lived in Wisconsin until 12/11. She's a Happy Hoosier now! I get lot's of people saying " What is that!" I love it!
Re: useing turbo block with out turbo, what needs to be changed? [Re: Shooter] #1042693 02/24/12 09:25 PM
goobuds Offline OP
my raider water pump does the same goes out to firewall to heater core. i will let you guys know more when i get them here and look. and compare.
i have pic of parts and peacies from what i got and ill take more when i get the t blocks. but all the help is nice.
question i have two heads both were from n/a blocks but on the casting on intake side on front it has T. cast into it and the othere has nothing?
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6411 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-05-29 15:34:04 UTC
