Montero Model designation research #1042769 02/24/12 08:12 PM
off-roader Offline OP
Please help me ensure this is right before I add it to the FAQ post.
One thing I'm not sure about is the availability of manual transmissions for each model year.
TIA...
Re: Montero Model designation research [Re: off-roader] #1042770 02/24/12 09:58 PM
Mister Bishi Offline
Ray, all 3.5 V6 had the V5M31 5sp.
I'm sure all 3.5 V6 had the V4AW3 4 sp auto and also later 3.0 V6 possibly from 96 on ? I'm pretty sure the only difference between the two auto's is the later one is fully ECU controlled the earlier one is more mechanical.
I just luv my "clacker Jabber".................
Re: Montero Model designation research [Re: Mister Bishi] #1042771 02/24/12 10:02 PM
Thanks Frank. I can't recall if the manual tranny gen II's ever came to the US. My initial guess is either no or yes with exceptionally limited availability. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Montero Model designation research [Re: off-roader] #1042772 02/24/12 10:13 PM
TainterRacing Offline
I just put a 90 auto motor in a 97 auto and the tranny is not at all the same. The 97 is a good deal larger the flex tq convertor is larger on it as well.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Montero Model designation research [Re: TainterRacing] #1042773 02/24/12 10:28 PM
That 90 probably had a KM148 transmission versus the larger gen II V4AW2 tranny.
There may be some level of error in the above as it was taken from Outer Limits 4x4's Pajero forum and they may have some inaccuracies. I'll modify the final copy.
Re: Montero Model designation research [Re: off-roader] #1042774 02/24/12 10:49 PM
Yeah I put the Outer Limits data together based on Oz models only obviously other markets may have different combinations.
Re: Montero Model designation research [Re: Mister Bishi] #1042775 02/25/12 12:33 AM
justice Offline
The gen 1 89/90 Manual trans is a bit beefier than the one behind the 4 cyl. Not sure about the # designation on the v6 gen1 manual trans.
Man trans was avail in the gen 2's in the US. I've seen them but they're rare.
Re: Montero Model designation research [Re: justice] #1042776 02/25/12 01:42 AM
That's correct :-
Gen 1 V6 had the V5MT1 5sp
Gen 1 V6 had the V4AW2 auto
Gen 1 2.6 had the KM145 5sp
Gen 1 2.6 had the KM148 auto
It gets tricky for the later model Gen 1 here in Oz as there was some mixing of 5sp boxes (no autos for the diesels) and indeed rear diffs. There was a V5M21 5sp used around 89/90 for both the 2.6 petrol & 2.5 diesels. We have also seen both 8" and 9" rear diffs in Gen 1 2.5 diesels as well.
Re: Montero Model designation research [Re: Mister Bishi] #1042777 02/25/12 02:28 AM
RECON45 Offline
so my 91 is a NG "No Good" <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Montero Model designation research [Re: RECON45] #1042778 02/25/12 02:17 PM
Hey Frankie, long time no see! Welcome back, thought the dingos had got you...
Early models also had a 3spd a/t, a torqueflite of some kind, maybe as early as 83 up to 86.
KM148 and the first vw4x are the same tranny, different name. I think KM145 is the same as V5M21, too, alloy case 5spds with 4g54 2.6 wideblock bellhousing, also fit diesels. V5MTx's were iron case 5spds will alloy bellhousings.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6426 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-11-03 13:40:04 UTC
