Gen 2 Alternator in a Gen 1 #1043055 03/01/12 12:10 AM
RECON45 Offline OP
I was wondering if one of the high output 180A alternators that fits the 3.0 Gen2 will bolt up to the 3.0 Gen 1
Re: Gen 2 Alternator in a Gen 1 [Re: RECON45] #1043056 03/01/12 12:29 AM
W
willwinchforfood Offline
What years had these high output alternators? I looked on rockauto but didnt see any options for 180a just 75a. They have pics you can compare the Gen 1 to Gen 2. Ill keep looking. Also dont oil your head bolts.
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Gen 2 Alternator in a Gen 1 [Re: willwinchforfood] #1043057 03/01/12 01:07 AM
TainterRacing Offline
I run a 2gen(3.5L)100amp on mine. I had to modify it just a tad. Run a spacer and then I had to get a new belt as well.
I cut off the back part of the top mount, as it would not let me a line it up right with it still there. Then I used a large nut as a spacer. On the lower one you can see there what I cut off from the top. I did not have the oem bolt So I used it as a spacer there. I can get the belt # for you. I had to loesn the belt adjuster all the way and remove both idle pulleys as well to get the belt on there it was super tight fit. Would be nice to get a belt thats 1in longer then the one I got but it was all the parts place had in stock at the time I was there. I should do a white up on it some time.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Gen 2 Alternator in a Gen 1 [Re: TainterRacing] #1043058 03/01/12 04:02 PM
W
That is awesome, nice work tainter. I guess I will be mucking through the yard soon to pick up one of these.
John
Re: Gen 2 Alternator in a Gen 1 [Re: willwinchforfood] #1043059 03/02/12 03:03 AM
How to Swap a 3.5 2gen alt on a 1gen 3.0
1.Will need a spacer est 1/2in or a bit over.
2.Use Both OEM bolts
3.Hacksaw blade
4.Will have to get a new surptine belt larger about 2.5in longer. Stock is 53in so you want about 55-56in. I used a Gatorback 4050545 That is 54.5in
6.The belt I got was all most to short. But I was able to get it to work I have to remove both idler pulleys and put the belt on the alt be fore I bolted any part of it on and then was a pain but got all the 2 idlers back on and just have it as lose as it can be.
Sorry about the typo
Re: Gen 2 Alternator in a Gen 1 [Re: TainterRacing] #1043060 03/02/12 07:16 PM
P
PhantomSky2 Offline
Such a swap possible on a 2.6? More so mean...are the connections the same and such?
Re: Gen 2 Alternator in a Gen 1 [Re: PhantomSky2] #1043061 03/02/12 08:05 PM
I am not sure about that. Would have to change the pulley as well as the 2.6 is a V-belt not a serpentine.
Re: Gen 2 Alternator in a Gen 1 [Re: willwinchforfood] #1043062 03/02/12 11:37 PM
Update!! I used a Gatorback 4050545 That is 54.5in you realy need more like a 55.5in I bet would work better.
Re: Gen 2 Alternator in a Gen 1 [Re: PhantomSky2] #1043063 03/05/12 03:41 AM
haztoys Offline
Look up a early 80's Dodge K car or van with a 2.6 ... Theres a 75 and 90 amp ($54 for a 90 amp on rockauto no core)... Its a big bodyed alt better duty cycle then the newer small bodyed alt stuff ... All parts to fix one are on rockauto if it goes bad ... Has a fan to cool it and two shiv v-groove pully ..Easy to hop up to 140 amp...
Re: Gen 2 Alternator in a Gen 1 [Re: haztoys] #1043064 03/05/12 04:08 AM
starion alt is hotter, and a bolt in.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6400 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-10-24 23:55:15 UTC
