Cheap 16in rims.. do any pick-up rims fit? #1043229 03/04/12 08:10 PM
TainterRacing Offline OP
I have a 97. Any help would be great!
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Cheap 16in rims.. do any pick-up rims fit? [Re: TainterRacing] #1043230 03/04/12 09:15 PM
Toyota 4Runner, Tacoma, T100, Tundra, FJ and Landcruiser wheels are likely candidates...being mindful of the backspacing. They are available in alloy and steel in 15", 16" and 17" diameters.
Montero Sports were also equipped with 16" steel and alloy wheels.
Nissan, Isuzu, GM products will have the same bolt circle; however, the hub diameters are not large enough without machining.
Unless you find aftermarket wheels?
Re: Cheap 16in rims.. do any pick-up rims fit? [Re: rxinhed] #1043231 03/05/12 03:12 AM
fatrat Offline
I know that aftermarket rims from my sons 87 4runner and my cousins 90's full size Blazer fit as they both had wide hub openings however the stock Blazer spare's hub was too small.
89 LWB V6 auto - LSD - OME coils, torsions, & nitrochargers - Rugged Ridge hubs -
Re: Cheap 16in rims.. do any pick-up rims fit? [Re: fatrat] #1043232 03/05/12 03:45 AM
goobuds Offline
wheel bolt pattern
so the link above will give u all the crossover info u could want. this was for my 88 radier but all you have to do is shearch for what you are looking for.
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: Cheap 16in rims.. do any pick-up rims fit? [Re: goobuds] #1043233 03/05/12 03:48 AM
6 on 5.5" is the lug pattern. Hub hole must be 4 1/8".
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6042 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-21 10:04:59 UTC
