Page 3 of 8 1 2 3 4 5 6 7 8
Re: 1988 Montero Turbo Diesel build [Re: TOASTY] #1043377 05/03/12 07:50 PM
TOASTY Offline OP
Took off the solenoid, it has corrosion. But the thing doesn't really come apart, it's stamped together any suggestions? i could grind the stamped dimples. I could also run it through a anti corrosion solvent and move it and shake it a bunch.
Re: 1988 Montero Turbo Diesel build [Re: TOASTY] #1043378 05/05/12 05:53 PM
LandRaider Offline
Pry out the stamped dimples. Then "stamp" them back after you've heehaw repaired it. Thats how I do it.
Re: 1988 Montero Turbo Diesel build [Re: LandRaider] #1043379 05/20/12 08:24 PM
TOASTY Offline OP
Starter is FAQ'd, either way here's some updates. the pics will resize eventually.
Cleaned and installed new rubber on the fuel tank, then installed that sucka
Stripping paint sucks, i stripped each section down to all shiny bare steel and then primed one section at a time. Here's the driver rear quarter panel almost stripped down and the driver door stripped and primed.
primed with the roof painted
Gloss white, and yes i know i didn't i didn't prep the roof as well as the sides but who's gonna look at the roof?
transfer cases with shifters installed
sight glass and breather fittings installed
Re: 1988 Montero Turbo Diesel build [Re: TOASTY] #1043380 05/21/12 02:03 AM
METALMOVER Offline
Looks awesome, my hat is off to you!METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: 1988 Montero Turbo Diesel build [Re: METALMOVER] #1043381 05/21/12 04:09 AM
TOASTY Offline OP
I might have also changed my mind on the main color as well, i found a dark green i really like.
Re: 1988 Montero Turbo Diesel build [Re: TOASTY] #1043382 05/21/12 01:16 PM
METALMOVER Offline
You might want to leave the top white anyway, if your in a state where theres lots of sun and hot temps. (wink wink)Just a thought.
Re: 1988 Montero Turbo Diesel build [Re: TOASTY] #1043383 05/22/12 02:06 AM
ryany Offline
That would depend on what kind of 4-wheeling you're planning to do with it.
95 Montero SR
Re: 1988 Montero Turbo Diesel build [Re: ryany] #1043384 05/23/12 07:06 AM
Alex Kogan Offline
Here is a perfect source for turbo diesel lovers. Late model 2008 Mitsubishi L200 crew cab pickup STATESIDE in Tucson. http://gsaauctions.gov/gsaauctions/aucdsclnk?sl=91QSCI12174531 According to VIN that thing supposed to have 2.8TD 4M40 engine, easy select. That's obviously a drug repo or something like that. I conversed with custodian
The truck doesnÆt run and hasnÆt in quite some time. The dash wiring has been cut, holes in dash cut. Interior is disassembled, exhaust system missing.
Sounds they were very thorough checking every hollow. Auctions ends TOMORROW!!! That might be only chance in loooong time to have something like that in us. Some enterprising sole might try to register that in non-emmission checking state. You'd be on your own. You should be able to source parts from Mexico where it's sold. http://www.mitsubishimotors.com.mx/index.php?s=modelos&m=detalle&a=9
08 PowerWagon (stock!)
Re: 1988 Montero Turbo Diesel build [Re: Alex Kogan] #1043385 05/23/12 04:51 PM
TOASTY Offline OP
Damnit. That would have been a cool thing to buy.
STARTED! [Re: METALMOVER] #1043386 06/02/12 10:03 PM
TOASTY Offline OP
Got the engine started today! Runs pretty good too, needs some fine tuning but this was the last big thing. I did the hot torque on the head and re sealed the valve cover. I can now start gathering the accessories and installing them so i can get this pig in the Montero.
Here's the video First running of the engine!
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6509 MB (Peak: 0.7772 MB) Data Comp: Off Server Time: 2026-10-24 08:15:31 UTC
