sporty cuts out after a few meters of going down the road #1043433 03/06/12 07:32 PM
freddiespyker Offline OP
hi guys i got a problem with my sporty after i have washed it underneath with the pressure cleaner.when i get into it start it and drive down the road a couple of meters it just cuts out i then stop put it in park switch it of start it again then it is fine again for the rest of the trip.i did replace the fuel filter today and it is still the same.is there any body on the forum with some advise <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043434 03/07/12 09:52 AM
shorty_sporty Offline
Check to see if you may have hit the plug on the air flow meter or if any water may have gotten into it at all.
Similar thing with mine when I got it, chased my tail for ages and it turned out to be quite a simple (but expensive) fix...
1997 Sportage - Extended forks, Dobinsons 2 inch front lift coils, rear Dobinsons TJ lift coils, GME UHF, $8 bullbar (I love eBay!)
2001 HZJ78 Troopcarrier - 2 inch lift, extended shocks, Ex Mine vehicle. Still has yellow reflective stripe! - GONE
2011 Toyota Aurion - For the wife!
Re: sporty cuts out after a few meters of going down the road [Re: shorty_sporty] #1043435 03/07/12 10:11 AM
i just went thru the sensor and nope it is bone dry i even went so far to drain my fuel to see if any water got into it and nothing i am on my way to remove the air filter from their i will go to the spark plugs thanx for the advise.i only washed the kia underneath now i am wondering is their anything under there that could cause this problem?
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043436 03/07/12 11:35 AM
Not 100% sure of the location of it, but it is possible that you could have accidentally hit the wire on the crank angle sensor which would also have a similar effect...
Re: sporty cuts out after a few meters of going down the road [Re: shorty_sporty] #1043437 03/07/12 02:47 PM
i also though of that it bolts on to the gearbox housing close to the exhaust manifold i will have a look at it the question is how do i test it? it might have got water in it with the wash.i just finished going thru the spark plugs and the coils could not find anything and it still does it the stalling thing the weird thing i noticed is that when it start to stall i put it in N and pump the gas then it stutters a bid and then it is fine again and off i go.i am going to lift the sporty up now so that it is better to work on if i find anything i will let you know.yet again thanks for the advise so far
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043438 03/10/12 10:30 AM
I would go get some electrical contact cleaner spray, remove the air flow meter from the intake pipe and give it a quick spray on the metal wires inside it. Just a quick spray and let it evaporate. Then put it back it and see if it helps at all. Be really careful not to damage the wiring at all, keep the can at distance of at least 20cm.
Re: sporty cuts out after a few meters of going down the road [Re: shorty_sporty] #1043439 03/11/12 06:12 PM
thanks again for the advise i still need to do that at this moment i am looking at the fuel pump i don't know how to test it to see if it is working the way it should so i am taking it in to get tested as well.i had the sporty at a tuning shop to read the computer for any codes but for some reason they can find anything wrong i even switch the crank shaft sensors with my wife's sporty(2003) and it still does the same.my plan was to switch fuel pumps today but i discovered that the wiring are not the same regards to the connecting plugs and i really don't want to go and cut wires at this moment i will let you know again if i come across something <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043440 03/13/12 01:33 PM
HI GOT THE FUEL PUMP TESTED AND THERE'S NOTHING WRONG WITH IT OR SO I WAS TOLD.THIS MORNING I SWOPPED AIRFLOW CENSORS WITH MY WIFE'S 2003 SPORTY AND THERE WASN'T ANY DIFFERENCE EXCEPTED A MINOR MISS FIRE SO I WILL PUT HER AIR FLOW CENSOR IN MY SPORTY TONIGHT TO TEST IT AS I WAS RUNNING OUT OF TIME FOR GETTING TO WORK <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043441 03/16/12 08:25 AM
STILL CANT FIND THE PROBLEM I HAVE REPLACED ALL THE RELAYS EVEN THE PETROL PUMP AND FILTERS PEOPLE IS COMING OUT TO REMOVE THE ANTI HIJACK SYSTEM JUST TO TRY AND NARROW DOWN THE SEARCH IF THIS MAKES NO DIFFERENCE ONLY ONE MORE THING TO DO ..... THE WIRING <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: sporty cuts out after a few meters of going down the road [Re: freddiespyker] #1043442 03/16/12 06:34 PM
ok they came to remove the anti-hi-jack system and still no change really don't know what else to do so i think i must go and look for the maim wire supply from a junkyard will keep you guys informed
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6372 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-05-29 22:16:35 UTC
