Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: PHIL_] #1043457 03/30/12 02:14 AM
johnnymarvello Offline OP
Thanks for hanging with me Phil. This is all new to me. When I went to NAPA, I got alot of blank stares and empty inventory searches. Here, they have to search under Dodge D-50 or Mighty Max, and most parts are, according to their system, obsolete. I did, numerous times, look through the forum parts list, but I got mixed up by looking at old Hanes manuels, and looking at RockAuto for numbers; I literally have a hanfull of numbers of each part. Obviously, part numbering is not very consistent; look on ebay and everything is out the window. I really appreciate any and all help you all can give. Cheers!
1987 SWB Montero, 4D55 TD conversion, Starion turbo, 5-speed, dual bouncy.
1985 MB 300D. Love Craft wvo conversion.
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: PHIL_] #1043458 03/30/12 10:18 PM
redbull Offline
Wasn't there a way to get the Wix 1067 from Peterbuilt or Kenworth as well? I vaguely recall someone saying the same filter was used on the heavy trucks.
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: redbull] #1043459 03/31/12 02:47 AM
pmontero Offline
There's some recent good news on the 1067 filter. a newer Hino diesel is now using that same filter so I've been able to find lots of stock in NAPA warehouses in the US now. They're not cheap but they're worth it.
Johnny, anti-drainback valves are needed for filters that mount horizontally. It keeps the oil from draining out of the filter when the engine sits. An empty oil filter is not good for the engine when you're cranking it. (unnecessary oil starvation)
-pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: pmontero] #1043460 03/31/12 04:54 AM
redbull Offline
That's good news, I just used my last filter! I buy 3 at a time from my local Napa dealer. What is "not cheap" now? I think I paid $27 per filter last time.
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: pmontero] #1043461 03/31/12 05:38 PM
Do I need to get the 1324 out ASAP! Would this explain my cold starting issues?
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: johnnymarvello] #1043462 04/04/12 04:47 PM
pmontero Offline
Johnny,
If it threaded on properly, you must have a different spec for the oil filter adapter. The 1324 wouldn't fit at all on my engine based on the thread pitch. The lack of an anti-drainback filter shouldn't cause cold starting issues. It would just cause extra wear on the engine over a period of time.
-Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: pmontero] #1043463 04/10/12 09:28 PM
rollguy Offline
I had a machinist buddy of mine re-thread the filter housing to fit a PH8A (I use NAPA equiv). It has about the same specs as the stock filter. I tried for a long time to find the big filter for my 4D55 (California emissions), and found them for $28 each. When I ran out, I had the oil filter housing re-threaded to fit the much cheaper oil filter (about $7 at NAPA).
All Diesel Fleet:
1985 Mitsubishi 2.3 Turbodiesel Pick-up, 1983 GMC Van- 6.2 Diesel.
Benzs: 1995 E300 diesel, 1980 300SD, 1982 300CD, 1983 300D, 1985 190D.
1980 AMC Eagle Limited Wagon powered by: 3.6 Litre I6 VM Turbo Diesel Engine (one of fewer than 10 made, only 2 known to still exist)
Re: Help with 4D55 air, oil and fuel filter part numbers? Glow plugs? [Re: rollguy] #1043464 04/11/12 06:05 PM
rollguy, that's an impressive fleet of diesels.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6288 MB (Peak: 0.7431 MB) Data Comp: Off Server Time: 2026-07-09 15:43:06 UTC
