'81 Benz 240d 4cyl diesel in a gen 1?? #1043578 03/09/12 12:04 AM
TresMon Offline OP
Hey fella's,
Been a while. I love my gen 1 but almost never drive it because I can't afford to put fuel through it except for BAD snow days and a few hunts close to home. I have been pondering a solution.
A friend of mine offered to GIVE me a good 1983 Mercedes 240D 4cyl diesel engine if I could make it work in my Gen 1 Monty.
(1.)Is that doable without the conversion being cost & labor prohibitive to the point of diminishing returns?
I would not mind to do a Pajero diesel swap but I can't find the motor and stuff.
(2.)Where would I look?
Thanks so much,
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: TresMon] #1043579 03/09/12 03:00 AM
Somebody on here did a 300d swap. He has the cad#'s for the adapter plate, but even with that it was not simple.
Stop and figure out how many gallons of gas you could buy with the grand plus minimum it will cost you even with a free motor.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: fasteddy] #1043580 03/09/12 03:30 AM
dougl3nc Offline
Obviously you have never driven a 240D! They are so slow it would have to haul ass twice just to roll down hill! I think the diesel generator I have makes more power.
300TD would be the smallest I'd go.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: dougl3nc] #1043581 03/13/12 03:49 PM
TresMon Offline OP
Thanks for the info. So what/where's the sources for Pajero Diesel motors?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: TresMon] #1043582 03/13/12 08:37 PM
spencevans Offline
The real issue with the the older Mercedes diesels are the are already maxxed out when it come to making power. There is no wiggle room, on most diesels you can crank up the fuel, but the fuel is already cranked up on these dumb things. You can make all the mods in the world but if you can't increase the fuel, it's all in vain. So not only are they slow, there is nothing you can do about it, not too mention they are not very efficient when compared to other diesels. On the bright side they are very reliable. The 4D56 is you best option if you are considering an engine swap.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: spencevans] #1043583 03/13/12 11:29 PM
johnnymarvello Offline
I don't know, those Sweds can get going.
http://www.youtube.com/watch?v=DmOUJQD3FDA
1987 SWB Montero, 4D55 TD conversion, Starion turbo, 5-speed, dual bouncy.
1985 MB 300D. Love Craft wvo conversion.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: johnnymarvello] #1043584 03/14/12 12:16 AM
TainterRacing Offline
Thats a turbo 6cly 3L-3.5L
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: TainterRacing] #1043585 03/14/12 03:35 AM
dougl3nc Offline
Try an inline 5, not 6! They run forever.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: dougl3nc] #1043586 03/14/12 05:17 AM
om603a Thats what motor it is and thats a INLINE 6 Thats what motor the guy that posted that vid says is in that car.
Re: '81 Benz 240d 4cyl diesel in a gen 1?? [Re: dougl3nc] #1043587 03/14/12 05:35 AM
redbull Offline
This is what I was going to say. I've driven a 240D. Walking is faster.
PHP: 7.4.33 Page Time: 4.605s Queries: 16 (0.081s) Memory: 0.6387 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-10-24 03:24:16 UTC
