Weird problem with 90 LWB ECU
#1043797
03/12/12 10:03 PM
Gang, I have been searching for an ECU for my wife's uncle 90 LWB ECU. The original ECU blew/ burned some resistors with a good display of smoke. Oddly enough, the truck will crank and run with the smoky ECU. Well, after some searching my wife uncle got another ECU. He installed it and guess what? it also went up in smoke burning the same resistors. <img src="/forums/images/graemlins/zombie.gif" alt="" /> I have not seen the ECU to guess what might be causeing the problem and my best guess is an issue with some shorting wires. But have any of you ever experience the same?
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Weird problem with 90 LWB ECU
[Re: JAVYPRO]
#1043798
03/12/12 10:16 PM
Mitsubishi Forum Moderator
I thought we talked on here about whether a shorted out idle control motor could cause the ECU to short, but that might have been a discussion related to one of my other vehicles.
My guess is that it is a short somewhere in the system, either a sensor itself or a sensor wire path maybe?
DougH 1997 SR - Current Lawn Ornament 1995 SR - RIP 1993 RS - RIP
[Re: DougH]
#1043799
03/12/12 10:20 PM
One of the places that repairs ecu's mentions that a damaged IAC/ISC can ground out the ECU causing it to also become damaged.
[Re: off-roader]
#1043800
03/17/12 01:26 PM
One of the places that repairs ecu's mentions that a damaged IAC/ISC can ground out the ECU causing it to also become damaged. That might explain why it will still run. We got plans to tear this thing up today, that is why I cannot be with y'all at the N GA run. Lets see what we find. Thanks Javy
[Re: JAVYPRO]
#1043801
03/17/12 11:45 PM
Well here we are beating it. We checked the ISC as per the FSM and it is within specs. Between connectors 1&4 it calls for 3.5-6.5 Kohms and we are reading 5.3. Between connectors 1&3 the resistance should change smoothly and it does. Connectors 1&2 with a depressed pedal it should read:non-conductive and with released: conductive. So, the ISC is within specs. Next step? Wiring and it is doesn't look fun at all.
Javy
[Re: JAVYPRO]
#1043802
03/18/12 10:33 PM
Where do the wires go? I would expect they would go to the ECU. I don't have a wiring diagram in front of me. Can you disconnect the ECU plug and run the same checks? This might help isolate a bad wire of connector between the ISC and ECU. Just my $0.02.
[Re: MarkG]
#1043803
03/19/12 11:41 PM
Where do the wires go? I would expect they would go to the ECU. I don't have a wiring diagram in front of me. Can you disconnect the ECU plug and run the same checks? This might help isolate a bad wire of connector between the ISC and ECU. Just my $0.02. Yep disconnect the ecu and run the same test from there. be sure the isc is connected.
Over the hill but still climbing. 88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
[Re: JAVYPRO]
#1043804
03/21/12 12:51 AM
Javy, don't know if you've seen this. Went though this about four years ago on my Sport. Testing it doesn't mean it's working. Mine tested within spec, too, but it still wasn't working correctly. DSMIAC Automotive - IAC/ISC SiteEnded up getting my replacement from them. Helpful bunch. Edward
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
