Motor mount bolts #1044013 03/17/12 08:18 PM
JohnnyMontero Offline OP
Hey there. I have a 1991 Montero LWB V6 w/manual trans
(I looked around through the search function and I couldn't find the info I was looking for.)
I am looking for the size/specs for a Gen1 v6 6g72 motor mount bolt. The 2 front/side mounts in particular.
I am running on 1 bolt on each side right now due to the previous owner never installing both on each side haha.
Not good... Its destroying different parts of my motor. Water pump, exhaust manifolds and such.
Thanks everyone.
~John
Re: Motor mount bolts [Re: JohnnyMontero] #1044014 03/17/12 08:50 PM
I sent a PM reply, but can pull these bolts for you, too.
Re: Motor mount bolts [Re: rxinhed] #1044015 03/17/12 09:11 PM
Thanks man
You have been a great help
I just need to know the size. Sunday I'll have the vehicle up on a hoist and I'll be able to easily access the mounts so I can put the bolts in. I just want to have the bolts before I go over there since I am on borrowed time.
~John
Re: Motor mount bolts [Re: JohnnyMontero] #1044016 03/18/12 02:15 AM
I believe the bolt diameter is 10mm.
Re: Motor mount bolts [Re: rxinhed] #1044017 03/19/12 03:46 AM
I pulled one at the yard today, looks like 10x1.5x45mm. That's eyeballing it. hope that helps.
Re: Motor mount bolts [Re: Mudraider] #1044018 03/20/12 04:25 AM
Thanks a bunch guys. Got that part sorted <img src="/forums/images/graemlins/cheers.gif" alt="" />
~John
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6103 MB (Peak: 0.6806 MB) Data Comp: Off Server Time: 2026-06-21 00:12:43 UTC
