Rolled my 4Runner... #1044690 03/30/12 09:28 PM
Staceman Offline OP
Pretty quiet on this board lately...
Here's something for you.
About a month after my "new" $50 rustolem paint job...
and 3 days after a new windshield replacement...
It all happened in slow motion. Once I felt it tip too far to the right, I simply grabbed the wheel, and tucked my elbows tight to my sides, and rode it down.
I have another windshield now, and am slowly fixing her up.
Next "mod" will obviously be an internal cage.
Things that happened:
My electric fuel pump worked as it is supposed to. Once rolled over, fuel pump stops sending fuel to the engine, and it shuts down.
Center console lid opened, and all the little stuff, like loose change, and spare fuses all ended up on the celeing. Not a big deal, just more cleanup.
My spare tire / hilift / and Co2 tank were ratchet strapped in the rear, and it held up just fine.
I have extended diff breathers, and lost just a little fluid from the diffs. My rear breather / filter is tucked in behind the tail lamp. Somehow, gear oil leaked all the way down the inside top of the bed rail on the drivers side. Not a big deal, just hard to clean up, and stinks up the garage.
Once back over, spark plugs were removed, (2 soaked in engine oil), EFI fuse pulled, and engine cranked a few seconds clearing out the oil that got into the cylinders.
Plugs back in, fuse put back in, and she fired right up, blowing out some blue smoke of coarse.
Drove her off the trail, and back to camp, where a few friends and hilift jacks got the old glass out, hole opened up, good enough to drive home. Laughing as the guys' told my to return my 3 day old windshield, because it was cracked ;-)
Trust me, windshields are a GOOD thing. Driving 65mph without one ain't all that.
So, keep your junk strapped down, and all the loose little stuff in a console or container that shuts securily. And of coarse, SEATBELTS. Glad mine was on. Did the job just fine.
Re: Rolled my 4Runner... [Re: Staceman] #1044691 04/02/12 12:35 AM
CJM Offline
CRAP .. so whats the plan ? I read you have a new shield , but obviously it wont fit in that hole ..
glad everyone is ok
83 Trekker SR5
NEW Trekker forum
Re: Rolled my 4Runner... [Re: Staceman] #1044692 04/02/12 01:39 AM
kewlynx Offline
Dang, glad you're okay. Did all the right things prior to and after the rollover. <img src="/forums/images/graemlins/kewl.gif" alt="" />
You should post a link to this over in the AZ crew board; got some talent over there if you don't already know some of those guys.
That add-on behind the cab is pretty rockin'; hope you're able to keep it.
**ubi apis- ibi salus**
Re: Rolled my 4Runner... [Re: kewlynx] #1044693 04/02/12 05:53 AM
A
allochris Offline
oh no! that remind me of our roll-over accident 2 winters ago, being hung upside down (luckly on snow!). Sure look scary landing upside-down on a pile of rocks....
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Rolled my 4Runner... [Re: CJM] #1044694 04/03/12 03:13 PM
Staceman Offline OP
Got the shape of the roof back. No go for a future sun-roof though. I'll just weld a panel over that hole. Got a stud-gun on the way in the mail. There is part of the body above the windshield that I cant get at with a hammer and dolly. With most of the interior out of the way, now is a good time to bend some DOM...
Windshield is ready to urethane in, but I wanna get more of the body straightened and filled in with it out of the way first.
Re: Rolled my 4Runner... [Re: Staceman] #1044695 04/03/12 03:48 PM
CJM Offline
that windshield piece .. header panel , is removable (spot weld bit)
I sure you know this , but it might be better to remove it , and get a good used one to put back in there , it will also help you get a great upper windshield line
83 Trekker SR5
NEW Trekker forum
Re: Rolled my 4Runner... [Re: CJM] #1044696 04/06/12 05:24 PM
OOP'S Offline
When I put mine on it's top in Moab a couple of years ago I replaced the whole top. Was not easy, but it done.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Rolled my 4Runner... [Re: OOP'S] #1044697 04/06/12 10:26 PM
Staceman Offline OP
Most of the body work is done. Just a few more tweeks before I glue in the new windshield I picked up. Internal cage to come shortly after...
Re: Rolled my 4Runner... [Re: Staceman] #1044698 04/10/12 06:32 AM
matts Offline
Sorry about your mishap. I look forward to seeing your 4runner rolling again. it's a sweet machine. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Rolled my 4Runner... [Re: matts] #1044699 04/10/12 04:43 PM
G
Greg_Canada Offline
No pun intended <img src="/forums/images/graemlins/shame.gif" alt="" />
LOL...
When i rolled mine they were able to pull it out. Yours... not so much.
Are you going to replace the roof or do a new body?
89 4Runner
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6478 MB (Peak: 0.7702 MB) Data Comp: Off Server Time: 2026-11-04 19:57:23 UTC
