Valve guide seals, correct? (Video) #1044961 04/06/12 12:57 AM
RyanB Offline OP
Adjusted the timing, and now I am smoking pretty bad. Always smoked for a few seconds on first start, but now I am smoking after idling for a minute on. Seems to be worse after the engine is warm, or if I get on it a little.
Quick recap - rebuilt the short block, didn't touch the head (saving up for a Clearwater). Just wanted all the expert opinions... I looked through all the old threads but didn't find any videos.
And thank you for my A/C question, my cheap "quick fill kit" gauge was not accurate, so even the lowest PSI was over charged.
Video
Thank you,
Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: Valve guide seals, correct? (Video) [Re: RyanB] #1044962 04/06/12 02:29 PM
Video
Thank you,
Ryan
Does it smoke when you first start it in the morning or after it sits off for a few hours?
Correct me if I'm wrong (don't have the 2.6 so I normally don't pay close attention to remembering details in those posts but I didn't think they had VSS issues?!? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Valve guide seals, correct? (Video) [Re: off-roader] #1044963 04/06/12 03:06 PM
RyanB Offline OP
Yes, smokes on first start and after sitting a couple of hours. That used to be the only time it smoked, now since I adjusted the timing it smokes after idling for a couple of minutes.
The valve stem seals on the 2.6 does not appear to be as big of a problem as with the 3.0, but this engine did sit for about 10 years... I know the head needs to be reworked/replaced, I guess what I am trying to get at is other than fouling plugs will this do any permanent damage to anything?
I don't drive it far (couple of miles a day), but I don't want to let it sit either. So until I can save enough for the new head I wanted to keep running it.
Thank you,
Ryan
Re: Valve guide seals, correct? (Video) [Re: RyanB] #1044964 04/08/12 01:52 AM
The VSS's leak into the exhaust port - not as bad as oil getting by the rings to burn in the exh chamber. You can drive it quite a ways without a ton of problems, but the cat will be coking up...
Re: Valve guide seals, correct? (Video) [Re: fasteddy] #1044965 04/11/12 05:15 AM
stony-man Offline
what would it hurt (for sake of argument) to remove the cat and put in a section of straight pipe, on a '92 V6 3.0?
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Valve guide seals, correct? (Video) [Re: stony-man] #1044966 04/11/12 07:26 AM
hochkis Offline
Nothing if you don't have to pass smog. might free up a single hp or two in the upper rpms.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6117 MB (Peak: 0.6833 MB) Data Comp: Off Server Time: 2026-06-07 06:10:00 UTC
