85 4runner auto tranny problem #1045362 04/17/12 05:30 AM
G
greenseaman Offline OP
I've been having a problem with my automatic transmission when climbing rocks. The shift lever physically shifts from drive to neutral. I just swapped out the lever because the original's OD button was messed up. The linkages looked fine. The transmission fluid level is also within specs. It also shudders really bad when putting it in gear. The transmission drives and shifts fine on the highway and down the trail, its just when I stress it trying to climb rocks. What am I overlooking? Thanks for the input!
Re: 85 4runner auto tranny problem [Re: greenseaman] #1045363 04/17/12 11:00 PM
4Crawler Offline
Any body lift on the 4Runner?
If so, you might need to adjust the linkage:
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#AutomaticTranny1
Re: 85 4runner auto tranny problem [Re: 4Crawler] #1045364 04/18/12 01:43 AM
G
There is no body lift. I'll try adjusting the linkage. Hopefully that'll work! Thanks!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5956 MB (Peak: 0.6490 MB) Data Comp: Off Server Time: 2026-06-22 07:35:33 UTC
