anybody tell me what or were this came from(pic)
#1045551
04/23/12 11:42 PM
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: anybody tell me what or were this came from(pic)
[Re: goobuds]
#1045552
04/23/12 11:56 PM
Just a WAG but if it's magnetic, maybe it's the magnet that normally sits in your oil pan?
[Re: off-roader]
#1045553
04/24/12 12:01 AM
i almost sure it came from my timing cover. iam thinking i put the wrong length bolt in one of my water pump holes. i looked at one of the other covers i have and it looks like its a dead ringer for it. makes me feel better i thought a rod bearing went.
[Re: goobuds]
#1045554
04/24/12 12:10 AM
[Re: goobuds]
#1045555
04/24/12 02:14 PM
Not all the short bolts are the same length and not all waterpumps have the proper thickness tabs so I expect you have popped the back off one bolt well. The part is out so you should be in good shape.
[Re: OldColt]
#1045556
04/24/12 10:43 PM
i know i should replace the t-cover but theres not water in the oil and no oil in the water. ummmm. i will i just really dont want to. lol. if i do that i might as well fix the exhaust stud i striped. and the replace the jet vavel seals.
[Re: goobuds]
#1045557
04/24/12 11:11 PM
If my mind were to wander to a question it would be, Is that the only one that broke through? Basically you got a part out that could create havoc if it were to get into a timing chain. Apparently it did not and with luck it was the only one in there. If the engine develops an oil leak up front from one of the bolts you will know which it was. Should this leak be bothersome, pull the bolt clean things up and apply a sealant, locktight blue would be plenty good to seal the threads and any cracks in the housing.
[Re: OldColt]
#1045558
04/24/12 11:41 PM
yes if it dont cause a problem why fix it. just when you got the parts. kinda makes u think. i need to get a new oil filter. so i can test it out.
[Re: goobuds]
#1045559
04/28/12 12:26 AM
Just started my rebuilt 2.6 for the first time today and i got coolant in the oil. Pretty sure because of this same issue because i had trouble getting the proper bolt in the water pump.
Anyways, think id be okay if i just put some good quality sealant in the bolt holes? Pretty much gotta strip the whole engine apart to get the timing cover off...
[Re: PhantomSky2]
#1045560
04/28/12 12:49 AM
well you could pull vavle cover and remove the water pump and shine a flashlite in the bolt holes to see if you can see light. might beable to pinpoint where and if it is the case. on side did you have the block deck resrfaced. and a good head that had been resurfaced.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6409 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-06-07 11:31:32 UTCValid HTML 5 and Valid CSS
