AC compressors? #1046751 05/17/12 06:07 PM
JeffatTireBalls Offline OP
Does anyone have a source or part number for an AC compressor for these 4d55/4d56 blocks?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: AC compressors? [Re: JeffatTireBalls] #1046752 05/18/12 05:13 PM
spencevans Offline
The Mitsubishi's used a small square compressor that mounted under the injection pump. The Dodges used a Sanden pump that was over the power steering pump. You may want to try to contact Mike Warme, I know he has several brackets and pumps. It will cost you a $300 to get the pumps rebuilt but it is well worth it.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: AC compressors? [Re: spencevans] #1046753 05/18/12 05:27 PM
Mine mounts below the IP. Thanks!
99 Montero SR
Re: AC compressors? [Re: JeffatTireBalls] #1046754 05/20/12 04:12 AM
redbull Offline
Would a photo help? I have one on the bench (actually floor) here.
Re: AC compressors? [Re: redbull] #1046755 05/21/12 01:56 AM
Yeah, I actually have a core.
99 Montero SR
Re: AC compressors? [Re: JeffatTireBalls] #1046756 05/24/12 04:20 AM
seattleraiders Offline
I have a half dozen of the different types sitting here on a shelf. One came off a pajero, one came off a delica, and the others came off something else. The brackets are the hard to find item in my experience. Anyway, drop a line if your interested, I can have a look over them and send you one cheap.
Check out nwmitsubishidiesel.com for fun....
Re: AC compressors? [Re: seattleraiders] #1046757 05/24/12 04:13 PM
I actually already have the mount...
Here is the compressor that I'm assuming is bad due to all of the oil on it...
Are the ones that you have new or rebuilt or known working units?...
99 Montero SR
Re: AC compressors? [Re: JeffatTireBalls] #1046758 05/24/12 08:32 PM
Anyone know if the 2.6 compressor bolts up to the diesel bracket?
Re: AC compressors? [Re: TOASTY] #1046759 05/25/12 06:48 PM
LandRaider Offline
You have to saw off one of the mounting arms, and then it will bolt in, but it will be about 1 belts thickness too far rearward.
<img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Ask me how I know. The compressor on my diesel motor was locked up. I guess I need to send it off to be rebuilt.
Re: AC compressors? [Re: LandRaider] #1046760 05/26/12 01:02 PM
I can't even find anyone that will rebuild them.
99 Montero SR
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6389 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-07-15 17:31:17 UTC
