Bump Stops??
#1046766
05/17/12 07:17 PM
Anybody got any Bumpstops or a part # for a set of Bumpstops for a SWB 89 V6?? ![[Linked Image]](http://i267.photobucket.com/albums/ii295/barryj01/Bump.jpg)
89 V6 SWB OEM Sunroof RPW Headers & Custom Exhaust 15" Toyota 4Runner Chrome Rims 33X12.5 Goodyear Wrangler Duratrac Stainless Steel Lugs
85 2.6 Montero (RIP) <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Bump Stops??
[Re: Bubba]
#1046767
05/17/12 08:08 PM
Anybody got any Bumpstops or a part # for a set of Bumpstops for a SWB 89 V6?? FWIW, those are the rear bump stops (there are front ones also). I don't have the p/n but you may want to doublecheck the part number repository thread (see FAQ post) or download the Mitsubishi ASA app to figure out the correct part number. It's a pretty simple and straight forward app but you do need your VIN number or a VIN number of a similar vehicle. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Bump Stops??
[Re: off-roader]
#1046768
05/17/12 10:56 PM
Now I know what your talking about. I used some of a jeep for my LWB. They might work. The mounting holes are a smidge off so you gotta make the holes about 1/8" bigger. Check the hieght to see if they will work.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Bump Stops??
[Re: heathdogg]
#1046769
05/17/12 11:47 PM
Is there a NAPA part (part#) thats available??
Re: Bump Stops??
[Re: Bubba]
#1046770
05/18/12 12:51 AM
I take it your are broken off and totally gone???? Mine (as you can see in that photo) are original and don't even have ozone cracks in them. Maybe cause my truck has lived without salt for 3/4 of it's years. They are a pretty hard rubber,,,and as I've said before Gen one rubber suspention and other rubber parts seem far superior than other auto makers(BMW comes to mind) and I alway try to get OEM rubber parts.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: Bump Stops??
[Re: KrzyDav]
#1046771
05/18/12 02:23 AM
. MB584148
$18.69
Stopper,RR Susp spring
(same part for left side)
I got part number cast on side of my bump stops. MB631470. That number has been superceded with the new number above. I recon they must use this on other models as it is avaiable at .com (Korum Mitsu, WA.) for net sources there's also the one in TX and the one in Maryland just reopened. At one time there was one in Longbeach,CA. Chose you poison.
Re: Bump Stops??
[Re: KrzyDav]
#1046772
05/23/12 07:08 AM
