engine struggling? - heres a simple solution #1046845 05/20/12 10:19 AM
hadtomer Offline OP
hey guys.
A friend of mine had a problem with is sporty - on serious acceleration it was lacking in power. everything was checked - sensors - catalitic converter - all were fine. finally he noticed that as the years pass - the lining on the inner part of the hood tends to sag and block the air intake. 10 minutes later and one pair of scissors - the sporty was back on its feet!
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: engine struggling? - heres a simple solution [Re: hadtomer] #1046846 05/20/12 05:04 PM
Everet Offline
This was written about a few years ago on the forum but it is a good reminder of something else to check!!
Thanks! Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: engine struggling? - heres a simple solution [Re: Everet] #1046847 05/20/12 11:22 PM
promodmerc Offline
I'll have to check mine. I know it's sagging enough that it is rubbing on the plastic engine cover.
Re: engine struggling? - heres a simple solution [Re: promodmerc] #1046848 05/21/12 03:16 PM
DRX350 Offline
That was one of the first things to go when I got mine. It looks a lot cleaner that way...
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: engine struggling? - heres a simple solution [Re: DRX350] #1046849 05/21/12 04:08 PM
promodmerc Offline
I've been seriously thinking of removing mine.
Re: engine struggling? - heres a simple solution [Re: promodmerc] #1046850 05/22/12 08:31 AM
2002_Sporty Offline
It gets sub zero in the winter where I live. So I have to retain mine to aid with keeping the lil 4-banger up to temp.
Good write up though.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6078 MB (Peak: 0.6776 MB) Data Comp: Off Server Time: 2026-10-26 07:26:33 UTC
