Window/Door sealant tape #1046869 05/20/12 07:09 PM
Chunky Offline OP
Regarding a 87 4Runner, I'm putting my doors together after getting it back from the paint shop. I was about to put the vent windows in and noticed the foam sealant tape has seen better days. No part shops around here carry anything that could be used, they all have double sided stick foam used to hold badges and molding to the body. This appears to be sticky only on one side. There are a couple other parts in the door that use foam tape, like the hanger receiver. It appears to be pretty high density stuff.
I've looked in part listings and can't find a number for it. I did some googling and found some makers of foam tape but was kind of overwhelmed. I wasn't confident that I would pick the right stuff. Anyone have experience with finding replacements?
'87 4Runner
Re: Window/Door sealant tape [Re: Chunky] #1046870 05/21/12 03:34 AM
CJM Offline
home depo , or any other type hardware store will have foam tape for windows ect.. it works great , check it out
83 Trekker SR5
NEW Trekker forum
Re: Window/Door sealant tape [Re: CJM] #1046871 05/22/12 03:27 PM
G
Greg_Canada Offline
I buy mine at Canadian Tire... of course you don't have that down there but i'd try a home store, or even RV / boat supply place. I have all different widths / thicknesses...
89 4Runner
Re: Window/Door sealant tape [Re: Greg_Canada] #1046872 05/27/12 05:27 PM
Chunky Offline OP
I went the home depot route. I found some single sided rubber-foam sealant tape that seemed to have the same properties. I'll get it on the freeway and see how it holds up to the wind.
'87 4Runner
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6007 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-07-14 10:49:48 UTC
