Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? #1046927 05/21/12 11:29 PM
off-roader Offline OP
Also need to drill a couple of 1/4" dia holes in it. I know a regular drill bit won't work so well so I'm looking for any ideas out there. My plan is to use a couple of Semi Mud Flaps and cut them down to fit on my 96SR.
TIA,
Ray
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: off-roader] #1046928 05/21/12 11:44 PM
RECON45 Offline
you can burn a hole through then use a drill bit to reem out the hole.
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: RECON45] #1046929 05/21/12 11:47 PM
How about cutting it? A heated up blade maybe?
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: off-roader] #1046930 05/22/12 01:35 AM
heat a 1/4" rod and burn the hole thru, then ream with a sharp drill bit.
I've also had luck with hole saws, but don't think they make them in 1/4".
I've also used a cheapo drill bit, and drilled steel dry to get it real hot, then immediatley drilled the rubber.
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: fasteddy] #1046931 05/22/12 02:05 AM
LandRaider Offline
Razor knife with a new blade. and a square. Don't slice your thumb off.
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: LandRaider] #1046932 05/22/12 02:13 AM
Grasscat Offline
Run them though a table saw.
I know a Monty owner who has one, but he's playing with boats right now, maybe you can sweet talk him into cutting them for you. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: off-roader] #1046933 05/23/12 07:09 AM
Alex Kogan Offline
Get some 1/4 steel tubing. Sharpen one end. Leave reasonable length for material to accumulate but not too long so it's bendy. Use as a a hole saw in a drill or better drill press. Lube it with some water/liquid soap when cutting.
08 PowerWagon (stock!)
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: off-roader] #1046934 05/23/12 12:02 PM
4ePajero Offline
Lubricate the rubber as well as the cutting tool liberally with liquid soap.
Trust me, it works!
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: 4ePajero] #1046935 05/23/12 02:22 PM
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Any suggestions for cutting 1/4-1/2" thick heavy rubber mat material? [Re: off-roader] #1046936 05/23/12 06:56 PM
geocrasher Offline
When working with rubber, use a water based lubricant. KY jelly is perfect, to be honest. I have a bungee that is used for launching RC gliders, and I had to get this big thing with an eyelet on it stuck into the rubber. Tried EVERYTHING. Lubed it with KY and it slipped right in and then stayed forever.
http://tidbitsfortechs.com/
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6348 MB (Peak: 0.7417 MB) Data Comp: Off Server Time: 2026-07-09 17:35:59 UTC
