Shackle Bushings? #1046937 05/21/12 11:47 PM
CJMT100 Offline OP
Trying to find new shackle bushings. I would prefer the polyurethane since they last way longer, but I cant even find the rubber ones. I did find them from an online toyota parts warehouse for 100.
Anyone got a source.
Re: Shackle Bushings? [Re: CJMT100] #1046938 05/22/12 04:39 PM
Perpetrator Offline
Check with 4Crawler, he's a board moderator. He builds custom shackles, but he may be able to hook you up with a good bushing source.
4Crawler's Product Page
From www.toyodiy.com I get the following for the factory bushing part #'s. The prices are pretty appealing <img src="/forums/images/graemlins/kewl.gif" alt="" /> :
48210A BUSH(FOR REAR SPRING SHACKLE UPPER)
90385-18017 RCK10, VCK1*, 2* Qty=4 $4.11
48210G BUSH(FOR REAR SPRING SHACKLE LOWER)
90385-18016 RCK10, VCK11, 21 Qty=4 $3.56
From what I understand, the poly bushings tend to be squeaky.
1997 T 100 4X4 ExtraCab
5 speed, White
Worthless factory bedliner
265/75/16 Firestone Destination A/Ts
Aisin Manual Hubs
90k miles
Re: Shackle Bushings? [Re: Perpetrator] #1046939 05/22/12 07:36 PM
CJMT100 Offline OP
Gees what the heck did I find then-I guess the price for the shackle itself.
Ill contact 4 crawler and see what he says, I dont want the rubber bushings b/c they tend to wear out too easy and I dont want to do this job again anytime soon.
Re: Shackle Bushings? [Re: CJMT100] #1046940 05/22/12 09:47 PM
G
Greg_Canada Offline
Energy suspension bushings are what i run.
89 4Runner
Re: Shackle Bushings? [Re: Greg_Canada] #1046941 05/22/12 10:59 PM
CJMT100 Offline OP
Got a link or part number?
Re: Shackle Bushings? [Re: CJMT100] #1046942 05/24/12 01:46 AM
CJMT100 Offline OP
Ive contacted 4crawler and am awaiting a response to have some shackles built with poly bushings. Im sure if I were to try and remove the ones on there now I would have issues due to rust and corrosion.
I also found daystar apparently lists toyota pick up 89-05 shackle bushings as fitting a t100. No idea if its right but I cant chance it once I have everything apart.
Also found a few new non oem shackles for about 70/pc online. Pretty reasonable but no idea the real quality.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6104 MB (Peak: 0.6800 MB) Data Comp: Off Server Time: 2026-06-20 18:14:34 UTC
