The A/C compressor on my 95 LS (3.0) has started clattering---
#1047082
05/23/12 11:35 PM
I noticed a week or so ago, that when I stepped out of my truck with the engine running, I could hear a distinct clatter coming from the area of the A/C compressor. I turned of the A/C,.......and sure enough, the clatter stopped as well, compressor back on, and the clatter began again. I have 240,000 miles on the truck, (runs great) and the A/C is icecold. Its still the original compressor,....hate to tear it apart with it still cooling, but, on the other hand, I dont want the compressor to disintegrate and fill the system with debris.
Any thoughts on this?
Brian in Austin
95 3.0 LS (24v) 241,000 miles and still going
Re: The A/C compressor on my 95 LS (3.0) has started clattering---
[Re: 95LS]
#1047083
05/24/12 11:51 AM
If the system has been leaking and you've just been topping it up without adding oil then maybe it just needs oil.
[Re: pcc]
#1047084
05/24/12 01:41 PM
If the system has been leaking and you've just been topping it up without adding oil then maybe it just needs oil. No, I have never needed to top it up.
[Re: 95LS]
#1047085
05/24/12 06:19 PM
Try adding some oil, then.
[Re: JohnnyBfromPeoria]
#1047086
05/24/12 07:15 PM
John B. Is it possible to be low on oil on a system that has never been opened and has always functioned fine (and, other than the clatter, still is) How do I add oil to a sealed operating system,....and,...how much would I add? Brian
[Re: 95LS]
#1047087
05/24/12 09:51 PM
How do I add oil to a sealed operating system,....and,...how much would I add? There are injection tools (I have one) that would keep the system sealed, otherwise you'd have to evacuate, add just oil and recharge, or oil with refrigerant. Adding oil to a system that has remained closed is a guessing game on how much to add. Too much, as you may know, will reduce the efficiency. Maybe the shaft bearing/sleeve is worn?? Try removing the drive belt and pull/push/shack the pulley to see if it has excessive play. You may need to lock the clutch with 12v jumper. Here's a site where parts may be available: http://www.acsource.com/index.aspxI've dealt with them and they are very reputable.
[Re: pcc]
#1047088
05/25/12 12:26 AM
The belt pulley has a bearing seperate from the compressor internal bearings, which may rattle only under load/clutch engaged...
[Re: fasteddy]
#1047089
05/25/12 06:26 AM
The belt pulley has a bearing seperate from the compressor internal bearings, which may rattle only under load/clutch engaged... Are you referring to the tensioner pulley or the pulley on the front of the compressor?
[Re: 95LS]
#1047090
05/25/12 06:09 PM
On the compressor. IIRC, the pulley has it's own bearing, independent of the compressor shaft bearing. I've had them go bad in the past. You can generally hear it with a mechanics stethoscope, a lighter rattle than with the compressor engaged..
