Suggestions for best source for A/C compressor, drier, expansion valve etc. #1047808 06/07/12 05:07 PM
9
95LS Offline OP
Looks like its time for a new A/C compressor.
Any suggestions for a good source for a compressor, drier, expansion valve. Its a 95 3.0 LS
Brian in Austin
95 3.0 LS (24v)
241,000 miles and still going
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: 95LS] #1047809 06/07/12 07:42 PM
P
pcc Offline
Not sure it's the "best" but he's a good guy to deal with and prices are low.
http://www.acsource.com/index.aspx
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: 95LS] #1047810 06/08/12 04:10 AM
METALMOVER Offline
Why do you say its time for all this? I recently charged my AC with a stop leak additive and its worked wonders. Should run around a 100 bucks and its worked on 2 of my cars now.Just a thought. METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: METALMOVER] #1047811 06/08/12 05:19 AM
9
95LS Offline OP
My Compressor clutch went up in smoke last weekend. Dont think your stop leak will fix that,...and general opinion seems to be, if the clutch is shot, I should replace the compressor and clutch as a unit, and if I am doing that,...gotta do a new expansion valve and drier to insure reliability.
Got 241,000 miles out of the original compressor clutch.
95 3.0 LS (24v)
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: 95LS] #1047812 06/08/12 01:42 PM
METALMOVER Offline
Yeah... I dont think so. good luck, sounds kinda expensive.
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: 95LS] #1047813 06/08/12 09:35 PM
P
pcc Offline
If doing all that I'd install new o-rings in the system as well.
Re: Suggestions for best source for A/C compressor, drier, expansion valve etc. [Re: 95LS] #1047814 06/10/12 12:07 AM
Try Rock Auto.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6174 MB (Peak: 0.6916 MB) Data Comp: Off Server Time: 2026-06-22 06:14:54 UTC
