Mitsu Diffrential oil #1047923 06/10/12 04:23 AM
matseel Offline OP
Can I put the OEM Mitsu rear differential oil [3775610] with friction modifier in the transfer case?
The 4 liter can is written in Japanese. Weekend project!
Hoping to finish tomorrow. Thanks....
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: Mitsu Diffrential oil [Re: matseel] #1047924 06/11/12 07:59 PM
IIRC the friction modifier thickens the oil. Not sure what the resultant affect would be on the xcase operation and longevity though.
Re: Mitsu Diffrential oil [Re: off-roader] #1047925 06/11/12 10:05 PM
LSD friction modifiers make the lock up plates more sliperry to keep the lsd from chattering in normal driving. I am not sure what they will do in a tcase, but many are not yellow metal compatible. I'd pass on using in a gearbox.
Gear Lube [Re: matseel] #1047926 06/12/12 02:54 AM
matseel Offline OP
Quick follow up! Called the stealer. Recommended Mits gearlube: A991ZC2X01
On a side note. The stealer wanted $67.00 for the rear diff oil for 4 liters 3775610 $67.00
Re: Gear Lube [Re: matseel] #1047927 06/12/12 04:23 AM
I know a gallon of 90 wt + additive is WAY less than that! <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> Must have some unobtanium additive in their lube. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Gear Lube [Re: matseel] #1047928 06/12/12 06:40 AM
Kevin C Offline
I have used Redline gear lube in rear diffs with LSD's with better results than the factory lube.
Re: Gear Lube [Re: off-roader] #1047929 06/13/12 12:06 AM
90wt is not a synthetic oil, the 75 wt oils and the Diaqueen are synthetics. The price for Mitsubishi's differential oil is quite competitive as far as top quality differential oils go.
What would you need a friction modifier in a transfer case for?
And why would you need a Hypoid oil in the transfer as well?
A top level oil you might consider in a transfer case would be Red Line lightweight Shock proof.
Re: Gear Lube [Re: OldColt] #1047930 06/13/12 07:51 AM
4ePikanini Offline
Best oil I find for the transfer case is Caltex Easyshift. It also works wonders for the Gen2 Pajero manual box's notchy 1st to 2nd gear.
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=77647&docFormat=PDF
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6294 MB (Peak: 0.7287 MB) Data Comp: Off Server Time: 2026-05-29 23:57:24 UTC
