custom fab work for 1997 montero ls #1048155 06/18/12 11:04 PM
G
greenmonty Offline OP
got custom fab work done on the monty will be posting up pictures soon, cost a penny but im keeping her for good.
any body on the las vegas area??
97 montero ls, 3.5 v6
custom front & rear bumper with swing away, Skids and multiple attachments
smitybuilt x8
custom sliders
roger brown 2"
OME Suspension kit
in the works:
full custom roof rack, HID lighting, 33" and front/Rear lockers/regearing.
Re: custom fab work for 1997 montero ls [Re: greenmonty] #1048156 06/19/12 04:33 AM
Angelo Offline
Interested in seeing the pics. What all did you get done? Been tossing around a lot of ideas for years, just haven't found anyone to work with yet
Re: custom fab work for 1997 montero ls [Re: greenmonty] #1048157 06/19/12 05:47 AM
hochkis Offline
North Las Vegas here. What kind of Fab work did you get done?
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: custom fab work for 1997 montero ls [Re: Angelo] #1048158 06/20/12 03:44 PM
G
new front bumper and skid plate with smity built x8 synthetic & rear bumper sway away with high jack and jerry can attachments, gas tank lift , OME lift & Roger brown body lift, sliders all items sprayed with textured coating and flat black paint.
in the works, Intake system,33's or 34's with regearing and maybe lockers while there in there, new custom roof rack from winsheild to rear door, (havent decided on the arb roof top tent or jumping jack trailer tent....)using the bolt holes from the old spare tire mount to build a detachable basket above the spare, enough for a cooler or other things. full skids from the back to front. on board air system..... CAN YOU SAY MONEY PIT!!!!!
smitybuilt x8
custom sliders
roger brown 2"
OME Suspension kit
in the works:
Re: custom fab work for 1997 montero ls [Re: greenmonty] #1048159 06/20/12 07:05 PM
Fwiw, a sway away tire carrier is the stock carrier is good for upwards of a 37" spare. A sway away Jerry can/HiLift mount would be useful though...
Re: custom fab work for 1997 montero ls [Re: off-roader] #1048160 06/21/12 02:43 AM
justice Offline
Uh...Not really. The stock carrier barely fits a 33 depending on your rim backspacing, and the tire rubs the back door. Sure you can space it out, but then its no longer stock is it? Upwards of a 37? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: custom fab work for 1997 montero ls [Re: justice] #1048161 06/21/12 05:27 AM
G
great guys,
but with the bouncing around over time and the bigger tires im putting on it will "stress the bolts over time", its a little inconvinente but she sure looks mean!!! jerry cans and hi jack are on the sway away, the jerry can attachment is removeable.
smitybuilt x8
custom sliders
roger brown 2"
OME Suspension kit
in the works:
Re: custom fab work for 1997 montero ls [Re: justice] #1048162 06/21/12 09:29 AM
Your that close to the back door? Fits my 35x12.5/15s on 15x10" rims w/ 4" backspacing. At the closest spot I have at least 1.5" of distance from my door. No mods done to the mount. What backspacing are you running Justice? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: custom fab work for 1997 montero ls [Re: greenmonty] #1048163 06/21/12 03:19 PM
I've been carrying 33x9.50, and 32x11.50 on the rear door with no issues of any sort. Plenty of others have carried bigger as mentioned. Put your fabbing money towards something other than the spare carrier...
Re: custom fab work for 1997 montero ls [Re: MontyMcV] #1048164 06/21/12 05:24 PM
35x13.5 6 ply tire on my unmodified carrier with a 10" wheel with a 3.5" backspace, been there for 6 years with no signs of wearing out hinges or bolts. Having said that i am probably going to make a swing down carrier to make it easier on my back removing and mounting my spare.
PHP: 7.4.33 Page Time: 0.009s Queries: 19 (0.005s) Memory: 0.6464 MB (Peak: 0.7886 MB) Data Comp: Off Server Time: 2026-06-10 01:46:35 UTC
