92 Montero engine re-assembly #1048305 06/21/12 05:54 PM
m4ff3w Offline OP
I've finally got the heads ready to go on the new-to-me block for my '92 Montero V6 auto.
The engine is out.
How far should I assemble the engine before placing it in the truck? All the accessories (power steering pump is still in the truck) and exhaust manifolds? What about the intake manifold?
Also, do anyone have any pics of an assembled engine on a stand? Just in case I've forgotten where some of the braces and brackets go.
Thanks yall!
-matthew
Re: 92 Montero engine re-assembly [Re: m4ff3w] #1048306 06/21/12 06:21 PM
FrankR Offline
Install the heads, valve covers, all front covers and exhaust manifolds with heat shields. Don't forget to install the driver side upper intake bracket on the rear of the driver side head. Install the A/C bracket, P/S pump bracket and alternator bracket. Install the crankshaft pulley, fan and tensioner brackets. Do not install the lower intake until the engine is in and bolted down - it will allow easier access to the upper bellhousing bolts.
Frank
Re: 92 Montero engine re-assembly [Re: FrankR] #1048307 06/21/12 06:53 PM
m4ff3w Offline OP
Thanks, Frank! <img src="/forums/images/graemlins/smile.gif" alt="" />
92 Montero SR
84 Maserati Biturbo
89 Mercedes 190E
77 Fiat X1/9
Re: 92 Montero engine re-assembly [Re: m4ff3w] #1048308 06/21/12 07:57 PM
4ePikanini Offline
here is my V6 build from a couple of years ago. Plenty of pics that might help.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: 92 Montero engine re-assembly [Re: 4ePikanini] #1048309 06/21/12 08:59 PM
m4ff3w Offline OP
The link didn't show up so I searched your posts and found it:
http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1157548
Thanks very much!
92 Montero SR
84 Maserati Biturbo
89 Mercedes 190E
77 Fiat X1/9
Re: 92 Montero engine re-assembly [Re: m4ff3w] #1048310 06/22/12 05:46 AM
KrzyDav Offline
I always put masking tape(I don't trust rags)on intake cause I like to drop nuts and such in manifold holes and whereever else I can do damage.
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6137 MB (Peak: 0.6841 MB) Data Comp: Off Server Time: 2026-05-29 22:33:43 UTC
