Would you drive if ya had a crack in the exhaust manifold? #1048331 06/22/12 01:23 PM
A
autobon7 Offline OP
Whats been the experience here? Its a 89 Raider V6 with 93XXX miles. Thought I had an exhaust leak....turns out it's the pass side exhaust manifold. Only exp I have is with my 95 Landcruiser, drove it for years without issue.
Thanks Morgan
PS Anyone have a crack free pass side exhaust manifold for sale?
1989 Dodge Raider
1995 Toyota Landcruiser
1975 BMW 2002
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: autobon7] #1048332 06/22/12 07:38 PM
LandRaider Offline
It'll be fine. Will get worse over time, and you will want to fix it.
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: LandRaider] #1048333 06/22/12 07:56 PM
A
autobon7 Offline OP
I have checked Rock Auto and msrecycling, neither has one.
1989 Dodge Raider
1975 BMW 2002
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: autobon7] #1048334 06/23/12 01:21 AM
sasnydley Offline
Will it be fine?-yes. Have I done it?-yes.
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: sasnydley] #1048335 06/23/12 02:25 PM
Lloyd Swartz Offline
Something like 99.99999% of Japanese vehicles, at least trucks end up with an exahust manifold crack...Not sure exactly why. My Nissan Titan has had them for quite awhile, most of my Monteros had them at one time or another. Toyota Trucks crack the day you drive them off the lot....I don't think they really hurt anything, just an annoying noise.
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: Lloyd Swartz] #1048336 06/23/12 02:32 PM
Homebrewer Offline
Check car-part.com and have a wrecking yard send you one.
Cracked manifolds are no biggie. It's not just Japanese vehicles that have the problem either. Google Jeep "Cracked Manifold" and you'll come up with about a zillion hits.
1989 Montero LS
1997 Jeep Wrangler
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: autobon7] #1048337 06/23/12 03:45 PM
Kevin C Offline
The down side is it may cost you a little bit of HP since that cylinder wont scavenge as well. Air leaks before the 02 sensor will throw off your fuel mix a little.
General experience says it's OK but there are side effects.
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: Kevin C] #1048338 06/23/12 04:43 PM
They can be welded up, nickel rod and heat the mani to about 500* first, then have the gasket flange flattened on a belt sander to remove some of the stresses. It also helps to cut the flange between the ports. This is an old trick on the 2.6 to keep it from pulling out the back stud, but it works on the 3.0, too.
I've only had one nipponese mani crack, on a 2.6T with uncut webs. Cracked right under the turbo flange, on the bottom.
Ditto all Kevin said...
Re: Would you drive if ya had a crack in the exhaust manifold? [Re: autobon7] #1048339 06/24/12 05:35 AM
KrzyDav Offline
seems there should be a passenger side in a yard somewhere. The yard down in SLO town has one , and they don't connect to carpart, etc. The passenger side should be the same 89-94. If you crack '89 drivers side , now that's a rarer find cause it's the only year with egr hole.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6287 MB (Peak: 0.7159 MB) Data Comp: Off Server Time: 2026-06-23 06:08:57 UTC
