Page 1 of 4 1 2 3 4
Spark Plugs and Wires for 95 SR #1048405 06/23/12 04:04 PM
TheViper Offline OP
So im thinking im gonna change out the spark plugs and wires on my montero. I have a good friend who is gonna help me with it as im not very mechanically inclined. After researching on here ive decided to go with NGK plugs and wires.
I was hoping someone can just confirm that ive chosen the right plugs and wires for my 95 montero
NGK (5464) BKR5EIX-11 Iridium IX
NGK 8692 wires
Thanks
1995 Montero SR
Re: Spark Plugs and Wires for 95 SR [Re: TheViper] #1048406 06/23/12 05:10 PM
PFR6J11 plugs per the FSM. This may be an obsolete number, so check it.
edit: You have the correct numbers per the NGK catalog...
Re: Spark Plugs and Wires for 95 SR [Re: TheViper] #1048407 06/24/12 02:19 AM
matseel Offline
I purchased these from
OEM spark plugs MS851335
OEM wire set MD311208
Good luck.
<a href="Mitsubishi online" target="_blank">http://www.oemmitsubishiparts.com/parts/...amp;searchText=</a>
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: Spark Plugs and Wires for 95 SR [Re: matseel] #1048408 06/24/12 07:05 PM
TheViper Offline OP
Good luck.
thanks for the input, but i think ill pass on $14/plug and $75 wires.
So i do have the correct parts listed?
1995 Montero SR
Re: Spark Plugs and Wires for 95 SR [Re: TheViper] #1048409 06/25/12 04:49 AM
Monster Offline
I installed the same spark plugs on my Montero 96 SR (NGK Iridium IX Spark Plugs BKR5EIX-11 # 5464).
Re: Spark Plugs and Wires for 95 SR [Re: Monster] #1048410 06/25/12 05:32 AM
TheViper Offline OP
thanks for the confirmation...how did the monty run after u put those new plugs in? could u notice a difference
1995 Montero SR
Re: Spark Plugs and Wires for 95 SR [Re: TheViper] #1048411 06/25/12 06:37 PM
Monster Offline
It had a bad cylinder before the engine rebuild with the old spark plugs (they were NGKs too) but it runs very smooth now, no lack in power whatsoever. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I am sure the last thing I would have to worry about in my engine (after installing those iridiums) would be spark plugs.
Re: Spark Plugs and Wires for 95 SR [Re: Monster] #1048412 06/26/12 12:01 AM
You spell that "iridium$$$$$$", but they are worth it. I got 137k out of a set on the wife's Subie 3.0 boxer6, and only changed them when the guilt got too bad - really didn't need to.
Re: Spark Plugs and Wires for 95 SR [Re: fasteddy] #1048413 06/26/12 02:20 AM
TheViper Offline OP
They r really not 2 bad as far as $$$$ goes, I got 6 of them for just under $40 and free shipping.
Thats shocking that those lasted you so long, thats crazy!
1995 Montero SR
Re: Spark Plugs and Wires for 95 SR [Re: TheViper] #1048414 06/26/12 05:44 AM
matseel Offline
I found the exact OEM spark plugs for $12.47 on amazon.com
Denso
The stealer is $10.40. FYI
Believe it or not some of the belts were cheaper from stealer than Napa. Just a thought
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-06-07 04:39:43 UTC
