My A/C clutch is out. Can I remove it with the compressor still on the engine? #1048557 06/27/12 06:11 PM
9
95LS Offline OP
Has anyone tried removing their A/C compressor clutch with the compressor still in place?
95 3.0 LS (24v)
241,000 miles and still going
Re: My A/C clutch is out. Can I remove it with the compressor still on the engine? [Re: 95LS] #1048558 06/27/12 06:37 PM
sasnydley Offline
I would think you would at least have to unbolt it and move it around so you can get an impact to pop bolts?or in order to get a puller.
Re: My A/C clutch is out. Can I remove it with the compressor still on the engine? [Re: sasnydley] #1048559 06/27/12 06:51 PM
mxmikie Offline
i have some 10P13/15 compressors
Re: My A/C clutch is out. Can I remove it with the compressor still on the engine? [Re: sasnydley] #1048560 06/28/12 04:53 PM
9
95LS Offline OP
SEE? That's why I come here,....that's a great idea I hadn't thought of! Thanks!
95 3.0 LS (24v)
Re: My A/C clutch is out. Can I remove it with the compressor still on the engine? [Re: 95LS] #1048561 06/28/12 09:46 PM
Pull the DS tire and it will make accessing some of the A/C bracket bolts easier. A swivel head stubby ratchet helps too.
Re: My A/C clutch is out. Can I remove it with the compressor still on the engine? [Re: MontyMcV] #1048562 06/29/12 12:02 AM
9
95LS Offline OP
Thanks for the tip Bill.
95 3.0 LS (24v)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6087 MB (Peak: 0.6776 MB) Data Comp: Off Server Time: 2026-06-22 06:13:11 UTC
