Adding an electric fan...suggest a keyed power source #1048613 06/29/12 01:22 PM
MrClean Offline OP
Hey all
Could someone suggest a keyed power source for my electric fan controller. It will be for the low amp side of the relay; I'm pulling the high amp side directly from the battery.
I'd prefer to put it on the left hand side of the engine compartment.
Thanky
Dodge Raider
  • 1989
  • 3.0L V6
  • 5 Speed MT
  • SWB
  • No back seat so the dogs can ride
Re: Adding an electric fan...suggest a keyed power source [Re: MrClean] #1048614 06/29/12 09:05 PM
P
pcc Offline
My Camry (and seemingly other vehicles) don't wire fan switch to ignition switch - "Caution Fan Starts Automatically". Turning the engine off does not prevent the fan from running.
Why do you want it wired through ignition?
Re: Adding an electric fan...suggest a keyed power source [Re: pcc] #1048615 06/29/12 10:14 PM
ES_97Sport Offline
My 'Bird is wired direct - doesn't turn off when the ignition is off. But that's because it has a carburetor. If I don't have a way to exhaust the heat from the engine bay the fuel will boil in the carburetor causing flooding and fuel spill issues.
My Montero Sport is wired into the ignition - everything is off when the ignition is off. But my Sport runs a Spal electronic fan controller and I don't want the controller on 24 hours a day, 7 days a week.
I've seen setups wired direct drain a battery to the point the vehicle wouldn't start. Lots of really short trip, start and stop driving in hot weather with a cheap battery.
My 'Bird fan will run for 10-15 minutes after it's shut off when the weather is in the mid/high 90s. Once in a while even longer. The ideal setup would be a timer - run for x minutes after key off and then shut off.
Depends on what you're trying to accomplish, I guess.
Re: Adding an electric fan...suggest a keyed power source [Re: pcc] #1048616 07/09/12 09:29 PM
MrClean Offline OP
Maybe it was a mistake, but I got an adjustable controller. It pulls a little power constantly even when the fans aren't called for.
Dodge Raider
  • 1989
  • 3.0L V6
  • 5 Speed MT
  • SWB
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6061 MB (Peak: 0.6630 MB) Data Comp: Off Server Time: 2026-05-29 17:26:38 UTC
