WTB: 90 v6 front diff gearing #1048929 07/09/12 01:41 PM
cruisn Offline OP
Alrighty, I am having a tough time sorting out gearing for my wagon. I was going to swap parts from my 92nh, I will take jsut the rear air locker diff. but for the front I need different gearing.
does anyone have 4.875 gears for the front diff for a 90 pajero v6?
its the 8" low pinion diff.
that would be a 91 montero for you guys since I am in australia.
90 Pajero - work in progress
Re: WTB: 90 v6 front diff gearing [Re: cruisn] #1048930 07/10/12 03:09 AM
KrzyDav Offline
I've only seen that ratio in our 92-93 SR Gen 2s,,,and they were 7.5 high pinion. I think there was an 8" front ring gear in the for sale maybe 2 months ago.
I think early 2.6 models had that ratio as an option, but it's probably a 7.5" low pinion, and very rare.
Hopefully someone more in the know will jump on here.
dave h.
Re: WTB: 90 v6 front diff gearing [Re: KrzyDav] #1048931 07/10/12 05:32 AM
Spencer had the V6 gears for sale, but they're 5.29s:
Linky
<img src="/forums/images/graemlins/wink.gif" alt="" />
Re: WTB: 90 v6 front diff gearing [Re: cruisn] #1048932 07/11/12 07:07 PM
MI_Mitsu Offline
Ive admittedly not done a whole lot of research yet in axle gear ratio's, but I do have a complete stock rear LSD diff gear assembly, as well as a complete stock rear diff out of a Conquest/Starion that I once read was a popular swap out for the front diff on a Montero/Raider. Ihad hoped to one day read up on it some more and maybe attempt a swap and trial run myself - I jsut never get around to it. if anyone is intersted just shoot me a PM.
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: WTB: 90 v6 front diff gearing [Re: rxinhed] #1048933 07/11/12 08:44 PM
spencevans Offline
Linky
It's true, they are still for sale.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: WTB: 90 v6 front diff gearing [Re: spencevans] #1048934 07/11/12 10:56 PM
justice Offline
There's a Gen1 front ring and pinion set of 4.88's for sale in the for sale section. The mitsu part number for the 4.88's is also linsted in the the special part # repository which is linked in the sticky thread above.
Re: WTB: 90 v6 front diff gearing [Re: justice] #1048935 07/12/12 01:46 PM
cruisn Offline OP
do you guys round that factory 4,875 up to 4.88? jsut to make life easy?
Re: WTB: 90 v6 front diff gearing [Re: cruisn] #1048936 07/12/12 04:54 PM
heathdogg Offline
Yes we do here. When I worked at the wrecking yard and even here at NAPA, Gear ratio's don't always work out so they are simple. There is a ford ratio (I thnk it was ford) that was 3.545 but they list it as 3.55 for simplicity. Going 3 places is a little anal on a manufactures part.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6253 MB (Peak: 0.7246 MB) Data Comp: Off Server Time: 2026-07-17 01:12:31 UTC
