Different powertrain for a 89 montero? #1048937 07/09/12 05:27 PM
Darrell Offline OP
My faithful 89 Montero is getting old. It has about 250K on it. Original Transmission. Put in a used engine mainly because a shop screwed up a valve job. I would like keep this truck forever. However I am more and more trouble finding parts that are going bad. I expect this problem to get worse as time goes on. I've had to get junk yard parts for the last couple of things. I thought of a solution if it is possible.
Is there a newer powertrain that will fit into the 89 montero? I'm not talking about building something that requires a whole bunch of fabricating, but something that will fit. Like is there a more recent 3.0 engine but with electronics that are still being made.
I hope that makes sense.
Thanks!
Re: Different powertrain for a 89 montero? [Re: Darrell] #1048938 07/09/12 07:18 PM
LandRaider Offline
Get yourself some parts trucks.
Re: Different powertrain for a 89 montero? [Re: Darrell] #1048939 07/09/12 07:20 PM
hazy_daze Offline
Get to know the AZ crew...
Re: Different powertrain for a 89 montero? [Re: hazy_daze] #1048940 07/09/12 07:41 PM
What he said. If you do that, eventually you'll do the first suggestion. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Different powertrain for a 89 montero? [Re: Darrell] #1048941 07/10/12 01:46 AM
Fabricating newer parts onto yours will solve a bunch of issues. And heck, you're by the guys who aren't afraid to try just about anything.
Re: Different powertrain for a 89 montero? [Re: Mudraider] #1048942 07/14/12 12:55 AM
Yeah you're in the right place for finding parts easily and updating engines. You're welcome to stop by my place and i can give you a run down of your options like a straight over swap or something that takes a little work or a full on custom deal which isn't as big of a deal as it sounds.
I'm in Mesa/Gilbert area send me a PM if you want. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Caution; I may try to push a diesel motor swap <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Different powertrain for a 89 montero? [Re: Darrell] #1048943 07/16/12 08:34 PM
BottomFeeder Offline
Thanks!
Where in Phoenix are you?
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Different powertrain for a 89 montero? [Re: BottomFeeder] #1048944 07/16/12 08:41 PM
Darrell Offline OP
I-17 and Happy Valley area
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6230 MB (Peak: 0.7225 MB) Data Comp: Off Server Time: 2026-06-20 21:43:21 UTC
