Transfer case gear oil question #1049033 07/13/12 05:01 AM
promodmerc Offline OP
The owners manual specifies straight 90w for the transfer case. All I can find is 75-90w or 80-90w. Can I use a multiple viscosity gear oil in the transfer case?
Re: Transfer case gear oil question [Re: promodmerc] #1049034 07/13/12 05:28 PM
Peabody Offline
Yes, no problem. The blended oils are rated that way to indicate they will function in varying temperature conditions (i.e. summer/winter), with the high value associated with high-temp/reduced viscosity and the low value reflecting low-temp/high viscosity (hot and thin vs. cold and sludgy). Thus, the more extreme-range oils would be good for colder climates, such as the northern region of the U.S. In your neck-o-the-woods, 80/90 is plenty-fine... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Transfer case gear oil question [Re: Peabody] #1049035 07/13/12 06:30 PM
Thak you Mr. Peabody <img src="/forums/images/graemlins/smile.gif" alt="" />
I figured 75-90 or 80-90 was fine. We do hit negitive temps in Kansas City.
Re: Transfer case gear oil question [Re: promodmerc] #1049036 07/14/12 12:23 AM
I forgot to ask this.
What Allen wrench/socket size is the fill & drain plug on the t-case?
Re: Transfer case gear oil question [Re: promodmerc] #1049037 07/14/12 06:31 AM
4x4Wire Offline
Sorry, can't resist...
The size that fits... <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6086 MB (Peak: 0.6736 MB) Data Comp: Off Server Time: 2026-05-29 18:59:20 UTC
