Engine in - bad noise #1049144 07/16/12 05:32 PM
m4ff3w Offline OP
I got the engine in. However, when I turn it with the starter bolted up there is a not so good noise. The noise is there when turning by hand or via the starter.
I couldn't figure it out - but then went in the garage and found this:
Doh! It was still attached to the block that came out of the truck. The FWD block that I used didn't have that spacer on the crank. Engine is coming out tonight.
I can't believe I forgot it.
92 Montero SR
84 Maserati Biturbo
89 Mercedes 190E
77 Fiat X1/9
Re: Engine in - bad noise [Re: m4ff3w] #1049145 07/16/12 07:53 PM
Hey at least it looks like you've figured it out! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5878 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-06-10 01:52:26 UTC
