[Help] Spark Plug Coils, 95 SR #1049345 07/23/12 01:22 AM
TheViper Offline OP
I was attempting to change the spark plugs on my 95 SR on the Driver side. First spark plug went great, to my suprise. The seceond one and 3rd one, both, the boot and coil pack separted from each other. What do I do now, is the coil pack broken?
How am i suppose to get the boot out now?
Heres a pic, on what im talkin about...
http://tinypic.com/r/vwu6id/6
http://tinypic.com/r/foksw3/6
1995 Montero SR
Re: [Help] Spark Plug Coils, 95 SR [Re: TheViper] #1049346 07/24/12 03:38 AM
TheViper Offline OP
you guys are killing me today, where r all the experts <img src="/forums/images/graemlins/frown.gif" alt="" />
anyways, i had ordered 2 new coils, just in case the coils either, A)broke with me trying to get them off or B)were the cause of my stuttering.
i decided to go ahead and attemt to get the boot off, witch was one heck of a pain in the ***. I used two small pliers, to pull the boot off, and after many unsuccessful attempts, and rubber ripped of the boot, and the actual coils being banged up, i finally got them off
I thought for sure the coils were damaged, but amazingly they werent smile
1995 Montero SR
Re: [Help] Spark Plug Coils, 95 SR [Re: TheViper] #1049347 07/24/12 04:35 AM
mxmikie Offline
this is what happens when thepo did not use die elec grease on the boots if you stick a small pocket screwdriver under the edge of the boot you can slide it around the boot to cover and free it then you should be able to twist it and pull it out then you can stick it back on the coil just put die elec grease on the contact surface when you put it back in
Re: [Help] Spark Plug Coils, 95 SR [Re: mxmikie] #1049348 07/24/12 03:27 PM
TheViper Offline OP
thats a good idea (small screwdriver), my hands are so big though it was tough enough with pliers. I tell ya, the coil packs were very loose on the boot, i couldnt twist the boot at all with the coil attached to the boot
1995 Montero SR
Re: [Help] Spark Plug Coils, 95 SR [Re: TheViper] #1049349 07/25/12 07:27 PM
TheViper Offline OP
Can someone tell me how long these ignition coils are suppose to last in the montero?
I just bought 2 of them....but im gonna test the other ones with a "ignition spark tester" before i replace them, is this tester a reliable way to test the ignition coil?
1995 Montero SR
Re: [Help] Spark Plug Coils, 95 SR [Re: TheViper] #1049350 07/26/12 12:36 AM
Howah Offline
95 Montero SR
Re: [Help] Spark Plug Coils, 95 SR [Re: Howah] #1049351 07/26/12 01:51 AM
TheViper Offline OP
thanks bro, thats absolutely perfect!
im no nothing about electrical systems, luckily i have a multi-meter, its weird that you dont need a power source at all
1995 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6207 MB (Peak: 0.6964 MB) Data Comp: Off Server Time: 2026-06-07 09:10:59 UTC
