Transmission ATF fluid *DELETED* #1049352 07/23/12 02:37 AM
matseel Offline OP
Post deleted by matseel
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: Transmission ATF fluid [Re: matseel] #1049353 07/23/12 05:09 AM
My AT's in 3 out of 4 rigs have each had over 200k using standard compatible dyno fluid. The one is a lower mileage rig so its not as high a mileage. That said, unless you're racing or using it as a work rig, I'd bet money it's not worth the extra added expense of synthetic ATF and with the potential cost that can happen with the wrong fluid (remember the Mobil 1 mitsu tranny compatible fluid that ate up Doug B's tranny??) I think it's just foolish to try with the potential risk...
Re: Transmission ATF fluid [Re: matseel] #1049354 07/23/12 05:18 AM
LandRaider Offline
http://www.4x4wire.com/forums/showf...4&an=0&page=0#Post650314
Title your Post Appropriately. If you have a specific question, put the specifics in your title. A good example would be: Gen 2 3.5 ltr Crank bolt problems,OR My Gen1 is smoking after start up. A poor example would be Help me please my truck Suxor!! OR "Transmission"
Also you've got some horrid acronym usage going on in that title. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Transmission ATF fluid [Re: LandRaider] #1049355 07/28/12 08:22 PM
leadheavy52 Offline
I flushed and refilled with Castrol Import, which specifically lists the Mitsubishi Diamond III as a compatible brand. 20k since and not a single problem. It even cured some small slipping issues that had begun to arise when the tranny was cold. If I could have easily located or afforded the Diamond III fluid, I would have gone that route, but the Castrol has been good to me so far.
-Austin
1988 SWB Montero - 2.6L - 5-speed
Weber Carb
(Coming Soon) Rugged Ridge AVM Hubs
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6019 MB (Peak: 0.6587 MB) Data Comp: Off Server Time: 2026-07-16 03:41:20 UTC
