Driveline adapter
#1049496
07/27/12 04:57 PM
I had an idea last nite. It involved making an round steel adapter that bolts onto the stock axle and would allow a regular bolt on u-joint flange to attach. I was thinking along the lines of the t-case adapter. 4 counter sunk allen heads to bolt to the axle and studs maybe to hold the driveline on. What are your thoughts?
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Driveline adapter
[Re: heathdogg]
#1049497
07/28/12 02:34 AM
...and the purpose?
Does this guard against zombies?
[Re: rxinhed]
#1049498
07/29/12 08:29 PM
Not for zombies though... I was think along the lines of using a jeep yokes on both ends when I put the 231 case so I wouldn't have to mess with trying to get the mistubishi yoke to fit on the new drivelines.
[Re: heathdogg]
#1049499
07/29/12 11:20 PM
your gonna need new driveshafts with the 231 so you may aswell not mess with that kind of setup.
89 2 dr turbo diesel 89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6022 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-05-30 01:17:42 UTCValid HTML 5 and Valid CSS
